ALH Possible bent rod advice?
DCELL
Sheridan, IN
'01 GOLF 2DR, ‘15 Passat SEL TDI
I'll try to make a long story short.
The car I am currently working on is the first I've seen that actually had timing belt strip itself and then the owner restarted it and let it run trying to figure out what was wrong with it. I've had others with suspected "slipped timing" or tensioner failure, but never one where my piston protrusion measurements didn't match up. As there are slight impressions from valves on the piston tops, I was suspecting the worst.
I used a variety of measurement techniques to try to determine what was going on with these pistons. I used both a magnetic dial base and a magnetic deck bridge as well as checking with both a dial gauge and caliper. Measured at the thin shoulder above the wrist pins after a conversation with franko6.
What I found was (left/right): #1=.041/.040, #2= .039/.040, #3 .039/.040, and #4 .042/.035
After measuring more times than will admit, I pulled #4 and #3 pistons for inspection, as I understand rods are weight and length matched in reciprocating pairs. What I don't know is what I'm looking at? Both of these rods look identical, and neither look bent to my eye. I don't have a surface plate at my disposal.
MY Question:
Is there any other way I can quickly determine the status of these rods without sending them to Frank? It's not that I don't want to send them out, it's more of an issue of time. He's already got the head rebuilt and on the way back to me.
Can anyone tell me in what way rods "normally" bend in a valve collision?
Many thanks!
Mavrick
Ontario
2003 VW Jetta TDI
The set of rods I replaced in my buddies ALH were very obviously bent upon visual inspection. The first 3 being within .002" I would not worry about. #4.. I personally would not even worry about that one as it's within somewhere between .001 and .005" - that could very well be from the factory..
DCELL
Sheridan, IN
my concern is that by measurement, the piston head on #4 itself is actually tilted, I pulled them to check for bends, but also to look for cracks or other signs of distress, but have found none. Perhaps I am being overly cautious.
greengeeker
Cambridge, MN
2002 Jetta GLS
Does the tilt coincide with your worst valve impact mark (and most trashed cam follower)?
I'm not used to seeing bent rods when the belt goes but I suppose anything is possible.
DCELL
Sheridan, IN
No, the tilt is opposite the impression, that's what was throwing me. The cam followers actually not spidered. I don't think it hit hard at all, so I'm kind of thinking it's just been that way since it was built
DCELL
Sheridan, IN
156k. Original belt is the one that broke.
I've decided I'm going to re- ring and throw them back in with new bolts. Fingers crossed.
Vince Waldon
Edmonton AB Canada
I personally think you'll be fine... very fine. :)
Those protrusion numbers look great to me, and if in fact a piston was tilted I'd suspect a worn bore or piston skirts rather than a bent rod, which you'll be able to check for as part of honing/re-ringing. :):)
Pat Dolan
Martensville, SK
2003 A4 Variant, 2015 Q7
Since you don't have measuring tools to do rod out, what I suggest is swap the #3 rod onto the #4 piston and vice-versa. If the error moves to the #3 hole, you have a bent rod.
