ALH ported head - "free hand"
burpod
teh stallionz!!1
cape cod, ma
this is my 3rd head i've ported - it's going to go into @braddies alh mk4 when we do an in-car rebuild (hone, maxpeeding rods, new rings).....
gasket matched.
left the swirl in the intake ports, just enlarged a little bit towards the bowl, shaved out a bit all-round.
exhaust ports opened up quite a bit, but kept the shape expanding in volume outward.
comments welcome. it's hard to get good pics of this stuff, did my best with my phone :)
it could use a bit better polishing, but i think is good enough. this one i was able to get done in <8hrs.
next head, i'm going to try and find some better bits and techniques for getting the final round a little more even and polished
tools used were mostly my 3000rpm drill + carbide burrs, but i did use makita 1/4 die grinder with a rough cut carbide bit to more quickly get the exhaust ports opened up. also a little bit of dremel for polishing, but it's really too weak, so i mostly used the drill + die grinder
GlowBugTDI
Cambridge, MN
What determines how much material you remove? In other words, how do you know how much you can remove before issues arise?
ducatipaso
Airhead Butcher
norcal
2002 Jetta TDI
have you tried doing volumetric measurements of each port? not flow, just actual interior volume?
burpod
teh stallionz!!1
cape cod, ma
no, i have not. i've used very basic method of using a medium stiff pipe brush and comparing visually and by feel :)
i've thought about using some silicone molds or something on a completed victim to be able to get a better idea how i'm doing, and then use those on the next head in order to get things more even/perfect, and then repeat that another time to achieve more "reasonable perfection".
i'll be testing this soon, on braddies car, as well as a similarly ported head on my ahu
i'm not sure what "reversion dams" are - i'll have to google that....
jmodge
Greenville, MI the winter water wonderland
More than I need, less than I want
There is no valve overlap to speak of...
Not sure what you meant by that, but I'm pretty sure you have a well above average education on TDI's from your posts and history. So I'll bite. Maybe I'll learn something new.
I don't have the cam specs for the TDI handy. Pretty much any internal combustion engine I am familiar with the closing of the intake and the opening exhaust valves overlap, as well as the valves overlapping peak or start of the stroke. Especially true with performance cams. This is what prompted the theory and application of reversion dams in head porting, from what I studied some 40 years ago.
From what I understand that valve overlap is intended to help start the flow of the next stroke cycle within the cylinder. The reversion dam buffers that action of back flow within the port, particularly at higher rpms, when porting has been modified.
So, is my understanding incorrect in your point of view? Do you not believe reversion dams are necessary or useful, and if not, why? Or am I missing something else?
I an also interested in your opinion on grinding out the guide where it protrudes into the port. In my thoughts it reduces the support of the valve and probably the guides and valves life expectancy, having friction take effect on a smaller amount of surface. So I would think in an engine built for longevity, No. Performance where it is torn down and inspected frequently, Ok. Doesn't seem the loss of support justifies the gain in volume, since the stem is still there. Some of my theories on porting, FWIW.
With due respect, looking forward to your thoughts
burpod
teh stallionz!!1
cape cod, ma
@jmodge - if yo're referring to the grinds i did on the valve guides - those were the old valve guides which were of course going to be replaced with new ones. i just left them in there for machine shop to r&r - certainly not going to be grinding those :)
jmodge
Yes and no, it also reminded me of the video of a guy porting ALH heads. He was dimpling them, then he ground out the guides, then I quit watching....because iirc he was doing it on purpose. So maybe I missed that part in the video also. Yeah, you did it the logical way.
GlowBugTDI
Cambridge, MN
I did not know that. So no valves open at the same in a given cylinder, no valve durations, exhaust or intake, overlapping into or from another stroke?
Are performance cams like that also? @Franko6
You can see this when you set the cam for TB replacement. Both lobes on cyl one are forming a v not pushing valves.
GlowBugTDI
Cambridge, MN
valve overlap happens at the bottom of the piston stroke.
Pardon my ignorance and confused understanding of what I thought I knew. That makes sense 100%, Not sure what I was talking about, but now I understand.
dieseldonato
Us
2001 jetta
Reversion dams are basically useless on forced induction engines. The exhaust side runs under pressure, ie back flow isn't really a concern. Low valve over lap also won't benefit from them. They only really need to be on the bottom of the exhaust port anyway, and again natural aspirated engines will benefit much more then forced induction.
ducatipaso
Airhead Butcher
norcal
2002 Jetta TDI
I have performance cams in the 24v - I love the exhaust burbles because of the overlap
jmodge
I thought about the forced induction factor. I don't agree at the moment that RD would be irrelevant because to make boost the exhaust would be restricted by the turbo vanes and exhaust manifold pressure would be present at the same time as boost. And with boost decreasing, emp would also, seems they may negate each other. Also boost isn't always present, as in cruising. But I've thought about that point, and I do it anyway.
They get put on the intake side also, just in the other direction. But, yeah generally on the exhaust where the port meets the exhaust manifold. Some manifolds have them cast into the collector, such as Sanderson's. I had a set of 2 1/2" center dumps on the stroker in my "72 K5. They were good quality BTW, solid, quiet, fairly cool, and flowed well.
jmodge
No it doesn't
Made me stop and ponder, That's correct, thank you. TDC, just not on compression stroke. sorry @GlowBugTDI
TDC at the end of the exhaust stroke as it begins the intake stroke. That is the overlap to which I speak of, and that is why I do reversion dams rather than gasket matching.
Aside from knowing the specs of any particular cam, it's no more effort grinding them in than it is to port match. So personally, I will always put them in, generally speaking.
GlowBugTDI
Cambridge, MN
No worries man. I have been blatantly wrong on several occasions recently, so I figured I was just wrong about what I thought made sense to me. Obviously I was able to be convinced otherwise so I wasn't completely sure.
jmodge
It happens, especially to people who are always trying to stuff 15 gallons of crap into a 5 gallon bucket ;)
dieseldonato
Us
2001 jetta
Possibly there could be marginal help, during certain conditions in a forced induction engine, I'm not seeing any in a turbo diesel with near zero cam over lap.
