Raweaver_410
- Joined
- Jan 16, 2014
- Location
- Cordova, MD
- TDI
- Mk4 Silver Golf TDI 5spd, Mk4 Red 2.0 Jetta Auto, Mk2 Blue Diesel Jetta 5spd, Mk1 Sandy Diesel Jetta 5spd
If by proper scan, you mean vcds, then yes I have and the codes are in the original post....don't seem to be anything that would cause a no start though. I guess the question is, do I just buy a pump, and also, who has one for me for a good price?
>a P0228 (Throttle pedal position sensor) signal too high-intermittent
>a P1540 (Vehicle Speed Signal) -signal too high
See these two codes?
Hear me out, on your crank position sensor test the resistance over 2 pins and move the wire around if the resistance fluctuates you need a new sensor. Check the connections to your throttle position sensor for damaged connections too. Before you go buying a pump, going and replacing parts is not how you learn/diagnose or figure out your problem. Five steps verify the complaint/problem, gather information, find most likely solution based on findings, made your fix, test your solution. Good luck anyone on here can help but I need more information to make myself useful.
