Hello, I have a ALH out of a 99 beetle in a mk1 rabbit. It's turning over but I can't seem to get it to fire.
I'm pretty confident I got the wiring correct, I'm using the 109 relay and verified it is closing when I send switched power to the ECU which in turn sends 12v power to the engine sensors.
I've triple checked the timing, cam lobes on cylinder 1 are up (valves closed) when the flywheel is at the TDC mark. Both the IP pin and cam tool fit in the slots.
I used a electric pump to push fuel through the filter and into the injection pump intil I had good flow out the return. I cracked the nuts at the injectors and cranked the engine over. I was getting fuel but it definitely wasn't spraying out. This makes me think its a fuel issue, I'm also not getting any white smoke.
Is this a IP issue? I have VCDS and can check values. Here is the fault codes, none of which would cause it not to start I believe?
I'm also questioning the fuel solenoid valve. When I turn on the switched power I hear it click and read 12v with a multimeter. It only stays on for a few seconds if not cranked. So what is the engine looking for when it sends power again? A rpm signal? I haven't been able to check it while cranking yet.
This engine has been sitting around for a few years, I was told it had 115,xxx and came out of a totalled beetle but was a good running engine.
Any ideas are greatly appreciated!
