guillaumeber
Hello!
I'm pretty sure this problem wasn't there last year.
Lately, I've been experiencing this problem a couple times as temperature is starting to go down.
Today, it was about 32-34 F outside. Started my trip with a cold engine.
Took exactly 30 miles (50km) of mostly high speed (50-60mph) to get to it's full operating temperature which is around 87C (about 190F on Scangauge II). I tought it was a pretty long way to get to temps compared to what I remember from last year.
Also, while coasting down a small hill or relasing go pedal for several seconds, I can see my temperature go down a lot, I saw it go down to as much as 75C ( about 167F ) .
Around here, temperature are frequently bellow 0F, down to about -22 in worst scenarios so I'm a bit worried as to whether I'll have heat in the cabin during winter time or not.
Most or my trips are about 10 miles and I remember getting to temp just when I was arriving at destination and it was way colder outside and I was traveling at much slower speeds. So I'm pretty sure I'm having an issue.
Yes, during winter nights I'm using a frostheater and I also use a blocked-off grill. (Should start using them soon) But while at work, I have no way to plug car and never got an issue starting it daytime when temperature is usually a bit ''hotter''.
I've checked my thermostat (which is about 2 months old) using the cooking pot technique, with a thermometer in the water, and It prooved good. Also put back my old thermostat in the car and same results happened.
Are there any other reasons that could lead to a colder than usual engine or causing an engine to cool too much?
Mucho thanks for the help!
G.b.
G.b.
