'01Doozel
Tale as old as time, someone with no VW TDI timing belt experience(myself), tries to replace their timing belt and has issues. Well here we are, and here are my issues.
2001 Jetta with 370,000mi, previous owner replaced timing belt at 316K, I bought at 353K. Water pump started leaking profusely because after a mess of thermostat replacement I ran out of G12 and substituted distilled water, long story short the lack of lubrication killed the pump. I replace the belt with help from my friends. I used the Cam lock and injection pump pin given to me by the previous owner. With a few speed bumps we get it put back together. Crosses fingers, cranks, and voila it runs! Albeit poorly. I thought a VW scanner that I also got from the previous owner would help me set the IP timing, it did not, attempted to do it by ear, no luck. Got it running ok, drove it home 30min with severe lack of power and rolling black smoke. Try messing with the IP again, test driving around the block, starts making terrible noise, get back, set IP timing back where it was before the noise, noise still there.
To me, the noise sounds like an injector with air, I replaced the fuel filter and did fill it with diesel but guess there still could be air in the system. Attached is a video of the noise, I haven’t run it since, it’s been sitting getting ignored for a couple weeks, but I need to get it going. Any help or advice would be appreciated. If it is piston to valve contact I know where a low mileage junkyard engine is for cheap that I may try to use.
