OK as promised a foolproof guide to replacing the front shaft seal on our ALH injection pumps without losing the hub to shaft timing...pics and subtitles beelow....
tools required: someway to hold the pump hub independent of the pump itself, this is my homemade tool (you can also just clamp the hub in a vice), a pump shaft lock bolt... a long audi flywheel bolt a ranger V6 bolt or a service tool such as the one pictured above that i removed from and industrial VE pump ... bolt size/pitch 10x1mm, i would say at least 2.25" long ... another potential source would be
some bicycle axles
"homemade tool" clamped in the vice with pump hub bolted up, pump lock pin in place
removing the plug from the lock bolt port
comparing the service bolt on right with the plug on left
shaft lock bolt in place snugged pretty good...you don't want the shaft to slip
loosen the nut and use a three jaw puller to pop the hub loose...I snug it good and tap the puller bolt with a hammer...finish removing the nut/lock washer and remove the pump from the hub..... it's not your eyes...the picture sucks!!
modified screw driver for seal removal
get the hook under the seal being careful not to mar the shaft and work the seal out carefully ...clean the shaft lube up the new seal and reinstall
reinsert the pump taper shaft into the hub (hub is still bolted to tool in vice)...reinsert the pump lock pin through the hub and into the pump lock hole ..install lock washer and nut and tighten nut to 59 ft lb .... finished !!
