HoneyBadger
Figured its about time to start my own thread. I've been nibbling on this project for a little over 2 years now, and am now starting to make some noticeable progress and figured I should start documenting what I've been doing to keep track of everything and to help any one else looking to do one of these swaps.
I want to give a shout out to greekgeeker also because his thread is what got me to actually pull the trigger on doing this project. I plan to follow his lead and put my own twist on the swap. More details later.
Seeing his actual mileage numbers took a lot of my doubts about the benefits of doing this project away. I'm tired of getting 14-17mpg in my ranger. Looking forward to 30+ hopefully 35-40+ !
The base:
1995 Ford Ranger 4x4 5 spd.
The donor:
Pulling the TDI:
Clean block waiting for primer:
Primered:
Painted:
Wiring Harness as I pulled from the donor:
All the gunk that was in the intake:
Reassembled:
I will not be pulling the motor out of the Ranger until May or June after I move. Right now I am just doing a bunch of prep work to get the new motor ready to go in.
Up to this point I've pretty much been doing maintenance to the engine and a little bit of stalling hoping that GreenGeeker was going to get his adapters for sale. Ended up with one from TDconversions, still in the process of getting it installed on the motor.
Things I've done so far:
Painted the block
Cleaned the intake
Timing belt replacement (and all associated parts)
replace broken parts from the accident
Started to remove unnecessary wires from Jetta Harness
Acquired an engine/trans adapter from TDConversions
Planned:
NB Radiator and fans
Similar intercooler as Greengeeker mounted in the same fashion
Use fuel pump from an 87 ranger diesel as a lift pump
Install a second fuel tank and have the lines installed(ready to install) before starting the swap then add the ability to use both once swap is running.
My ranger was offered with the passenger airbag as an option that was not installed, so if it doesn't become a giant PITA I am planning to mount all TDI related fuses and relays in this compartment as its empty real estate and would keep all of these components easy to access and safe from the elements.
I know there is more, but that's all I can remember tonight. Will update as I remember and think of other things.
The base:
The donor:
Pulling the TDI:
Primered:
Painted:
Reassembled:
Painted the block
Cleaned the intake
Planned:
