slamhouse
As the title states, would swapping an alh into a boat be a sensible idea? Not sure how the alh handles constant heavy load...
Which is exactly why you'd run heat exchangers and have a closed coolant loop system for the engine, just like a saltwater setup. Continuous high load is why I'd run the crafter (16.8:1 CR) pistons and and aggressive cam/port job. More airflow means lower egt's and lower CR for a lower pcp for given output yield less load on rod/crank bearings.FlyTDI is right. A marine diesel is a very different beast than a car diesel. First, the engine is protected against corrosion, particularly in the cooling system. Second, the cam set up and compression are designed for continued high-load use.
I have friends who have pulled 1970s Rabbit diesels for use in sailboats. The results were poor. <--- my second diesel is a Yanmar, with straight-through pipes and EGR delete, lol
I'm down anytime for crazy franken projects .Hey Matt, when do you wanna build this engine? I'll tow my boat up anytime for a swap. It's got a GM 4.3 v6 220hp with 25 hours on it.
http://forums.tdiclub.com/showthread.php?t=285037As the title states, would swapping an alh into a boat be a sensible idea? Not sure how the alh handles constant heavy load...
All diesel marine engine use a cloosed cooling circuit, so you have cooling fluid going through your engine like in a car, you just need a big enough water to water cooler and raw water pump.FlyTDI is right. A marine diesel is a very different beast than a car diesel. First, the engine is protected against corrosion, particularly in the cooling system. Second, the cam set up and compression are designed for continued high-load use.
Does anybody know if there are any adapters available to fit the VAG 4 cyl bolt pattern for a boat or would they have to be custom?
Wow I had no idea, thanks for that link!
Great idea, please document the marinization parts and processes. I'd like to put one in an I/O boat someday, looks like the merc TDIs are compatible with at least the Bravo outdrives. I just got done with a week in the keys running our Johnson 200, smoky, bulletproof, and thirsty! It'd be great to trade the thirsty for efficient.Looks like I might be building an ALH ski boat. Found an 89 ski nautique in mint condition with a sbf that has blown head gaskets or cracked heads. Guy is only asking $1500 and it's 30 mins away. Going to look at it tomorrow. If it's as good as it looks in pics, my friend and I are going to haggle him down as much as we can and split it. Damnit, another project.
You may never have seen one but many thousands of the smaller Yanmars and Volvos and other makes used to come standard as raw water cooled.All diesel marine engine use a cloosed cooling circuit, so you have cooling fluid going through your engine like in a car, you just need a big enough water to water cooler and raw water pump.
The 1970 rabbit diesel was also a poor result in the car...
Ski in NC;4241317Those sea water cooled engine (yanmar said:I wonder how Yanmar manages corrosion in their diesel outboards?
I hope the whole thing isn't cast iron!
