I have a friend with afn engine, .280 dss nozles bv50 turbo dbilas cam, 12mm pump, he is crazy and runs 2.5bar constant boost peaking at 3bar plus atmosferic pressure. Stock internals and stock head bolts he is taking part in locla slalom and rally competition, car is over 10000km with this setup the car is 4x4, he broke torsen 3 times, 2 times clutch failed, power is arount 150kw. And torque is around 500nm he can wheelspin in second gear straight, and 3rd gear in the corner. And he says that bolts is no issue at all. What he told thats important to have double valve springs so under high boost valves would not hang.
