libbybapa
- Joined
- Nov 15, 2011
- Location
- Where?
- TDI
- '83 AHU mTDI high top Vanagon, '84 AHU mTDI pop top Vanagon, '85 Franken-mTDI Adventurewagen Vanagon, '91 Vanagon ALH mTDI tin top auto, '02 Jetta eTDI Wagon, '02 Jetta eTDI Sedan
I have done a fair amount of searching and reading and have been unable to come up with the needed info.
I am working on a Vanagon that was converted to an ALH (I was told it is an '02) with the electronic engine management and the Mk4 instrument cluster. The conversion was not done by me so trying to sort it is somewhat frustrating. The glow plug light is currently not working. It does not turn on when the key is turned to the ON position. I have been unable to even find the glow plug light listed in the Bentley wiring diagrams for the instrument cluster wiring. Bentley 90-6 Instruments gives the pins for the two 32-pin connectors for the instrument cluster and shows the glow plug light (K29) as pin 13 on T32 blue but does not give any wiring colors for the bundle of wires.
Does anyone know what wire color that would be? Is that supposed to run to the ECU where the ECU grounds it to turn on the glow plug light? If so, which pin on the ECU should that run to?
Any help is appreciated.
