karlaudi
- Joined
- Aug 24, 2005
- Location
- San Francisco Bay area
- TDI
- 2002 VW Golf GLS 1.9TDi; 2012 Volkswagen Golf 2.0 TDi
I have a 2002 Golf GLS TDI (ALH). Always dealer serviced since new and almost always within a few hundred miles or less of recommended intervals.
About a week ago, on the eve of it's 160k service, my wife and oldest daughter noticed it starting to overheat during a typical SF Bay Area commute. Resourceful, my daughter accessed the internet via her iPhone and quickly deduced to run the heater on full and the engine never got above three-quarters on the temperature gauge, according to them. As long as the heater is on the engine operates at normal temperature; performance is normal. It has been this way for a week.
My dealer has had it for two days. Initially they confirmed a failed radiator fan thermo-switch. Now they are saying, after conferring with VOA, that though there is coolant flow through the radiator and the system is not being pressurized by exhaust gases and there is no evidence of coolant in the oil or oil in the coolant, the head gasket is blown and maybe the head is warped because the upper radiator hose is hot and hard and the lower radiator hose is cool and soft.
Any comments or experience to share?
Note: Water pump was replaced at 80k during the timing belt change, but I need to check my records on a thermostat.
Thanks for any and all input and suggestions.
