There is absolutely nothing special about the ALH, its a 4 cylinder DI turbo diesel engine. I am thinking 505 at the time might have been to protect the cat from damage.What does the 505 mean? Really? The only things unique with the ALH engine is being diesel and it has a Turbo. The synthetic provides protection to the Turbo while diesel rated helps deal with the soot. All diesel rated oils deal with the soot ........... heck they were dealing with the soot 50 years ago and the big rigs were going 400 to 500k miles on the engines even back then. I remember changing oil on a refrigeration unit powered by a 4-cylinder diesel back in the early 1970s ............. that oil was extremely black! The guy said it had not been changed in two years, if I remember correctly.
Never said VW approved it. Just going on common sense. Dino 15W-40 gets put into engines everyday with turbos.Did not the original Manual for the ALH specify conventional oil?
I think the synthetic is more for the TC than the engine???
That's actually a common myth. Oil pumps are positive displacement. If your ambient temps are within the operating range of the winter rating and the oil hasn't started to crystallize than a 15w will flow the same as a 5w or even a 0w. The lower winter rating only has an advantage as you approach the lower operating range of the synthetic 15w ( < -20c) where crystallization of waxes in the base oils begins.I wouldn't run the 15w40 in cold weather but in warmer climates it's likely perfectly fine. Most wear occurs at start-up and the faster you can get oil under pressure into the journals the better.
Yes, the pump is positive-displacement. However, it has a relief valve at its output typically set at ~60psi and therefore develops no more than that. The oil must be pumped into the passages and fill the void spaces in the journals before full lubrication is established, and the velocity of that flow is materially lower for a thicker oil. Until it does the excess the pump is able to deliver is dumped through that pressure-relief valve straight back into the pan and the fill rate of those passages is slower the higher the viscosity.That's actually a common myth. Oil pumps are positive displacement. If your ambient temps are within the operating range of the winter rating and the oil hasn't started to crystallize than a 15w will flow the same as a 5w or even a 0w. The lower winter rating only has an advantage as you approach the lower operating range of the synthetic 15w ( < -20c) where crystallization of waxes in the base oils begins.
Yes, the pump is positive-displacement. However, it has a relief valve at its output typically set at ~60psi and therefore develops no more than that. The oil must be pumped into the passages and fill the void spaces in the jw40ournals before full lubrication is established, and the velocity of that flow is materially lower for a thicker oil. Until it does the excess the pump is able to deliver is dumped through that pressure-relief valve straight back into the pan and the fill rate of those passages is slower the higher the viscosity.
This is obviously an extreme example but with the Detroits in my former boat (which required a straight 40wt; multi-grades do not meet specs) when exercised in the winter months in Florida, with outdoor temps right near freezing, the time-before-normal-pressure on the mechanical gauge in the engine room was roughly double that in the summer with both being "first crank" after a couple of days since last being run. Until the oil fills the airspaces in the system and expels that air, which is a function of its flow rate down those passages there is effective no pressure component to the lubricating film in the main and cam bearings at all.
The difference in time before the minor lifter tick goes away between a "first morning" 32F start and an 80F start on an ALH -- with 5w40 -- is clearly discernable. I'll bet with 15w its materially longer.
Is that difference on a cold start going to kill the engine? No, but I'll bet it shows up in the wear metal levels if you run UOA and eventually in the service life of internal engine parts. With dino oils the use of VIs to attain the multi-grade rating means that over time you run the risk of losing the higher-end ("hot") rating due to shear, which is why with those oils its best to use the narrowest spread that meets operating and temperature range requirements. That concern does not apply in the general sense with fully-synthetic base stocks.
There is also the hydrodynamic film strength factor, especially on an engine tuned to produce more output (and thus more load on the mains and rod bearings) than originally designed for but for fully-synthetics with the same top rating (5w40 .vs. 15w40) that shouldn't come into play. For dino oils it definitely does once again due to their extensive use of VIs to get that wider rating.
In this case, however, both oils are full synthetic base-stock.
There is no expected advantage to running a 15w40 full-synthetic where a 5w40 full-synthetic is specified and there may be, in cold weather at least, a disadvantage in terms of start-up wear. If you're going to do it I would pull UOAs on both under the same environmental conditions.
The owners manual for my 2003 ALH TDI said either 1) VAG 505.00 or 2) API CH-4.Hi everyone, im currently running motomaster 5w-40 in my alh with 300 thousand kilometers. Im going to be doing a oil change soon and was wondering if I should switch to shell Rotella synthetic t6 or mobil Delvac 1. I heard those oils offer better protection but It does not meet the 505 spec.
I've got a jug of synthetic 15w40 that I'm using for topping-up. But won't be using that viscosity for any oil changes.Interestingly, I've seen T6 Rotella in 15w-40 (synthetic). That stuff might be worth considering for the high mileage ALH.
Nope, it's scarce out here too. I read a post that said it was due to not being able to get the additives.Ya know......I haven't seen a jug of T6 on the shelf anywhere around me for a couple of months.
My 10w40 blend is posted on “Bobby’s oil forum” “smart guy”. I post all of my used and virgin oil analysis on there. You could learn a lot from bobistheoilguy.com instead of believing your silly notions and myths.So much miss information in this thread. From saying a Diesel rated 15w-40 Conventional has no place within an oil-cooled turbo to mixing oils and saying it’s the “Bees Knees.”
post some of this garbage on Bobby’s oil forum and you’ll get lit up.
Best bang for the buck right now is 15w-40 Delvac Extreme. Very nice adpack, 4.1 Shear, etc. then the rebate. Forget Delvac 5w-40 as it isn’t any better and depending on usage, will degrade quicker than the Extreme.
Keep it to the facts, not Grandpa’s old tales.
Oh boy. I know how to read an SDS quite well and saw your back and forth in Bobby’s forum. Group 4 and 5 show only a part of the equation and do not show add stocks. You even fell into the trap with that “Wally” poster stating Extreme is not even synthetic.My 10w40 blend is posted on “Bobby’s oil forum” “smart guy”. I post all of my used and virgin oil analysis on there. You could learn a lot from bobistheoilguy.com instead of believing your silly notions and myths.
RLI 10w40 Homebrew Bio-SynXtra HD Low Ash VOA
The 10w30 RLI I got was kinda low on the cSt @ 100 so I decided to mix it with the 15w40 to make it a 10w40. I also wanted to see how two multigrade oils of the same formulation would blend together. Kinda like an experiment. 50/50 Homebrew Blend of RLI Bio-SynXtra HD Low Ash 10w30 and 15w40...bobistheoilguy.com
Delvac ESP 5w40 has superior base oils including group IV and V. Delvac extreme does not. If you knew how to read an SDS you could tell the difference between the two products.
I say “smart guy” sarcastically because you’re full of do-do and shouldn’t be criticizing others because of your own ignorance.
Protect it from Conventional oil? You’re a silly man.Sorry for you guys that are looking for oil. Over the last year I scoffed up enough to last way more than 100k miles and laid back a good number of filters, including air and fuel.
Remember to protect your VNT Turbos ....
Homebrews are just that…home brews. Posting for others to do the same is asinine at best.
[/QUOTE
Like I said, full of do-do. You also have poor reading comprehension.Oh boy. I know how to read an SDS quite well and saw your back and forth in Bobby’s forum. Group 4 and 5 show only a part of the equation and do not show add stocks. You even fell into the trap with that “Wally” poster stating Extreme is not even synthetic.
You've got a really old Owners Manual since it authorizes API CF-4 rated oil. Mine said CH-4. Now diesel-rated oil is CK-4.I dunno why you guys need to complicate and argue in an oil thread.
Cheap…lol. That’s a good one.Like I said, full of do-do. You also have poor reading comprehension.
I only shared my own experience, to dispel myths about 10w and 15w oils. I never advocated or recommended any one follow my lead, however they could safely do it as I have a literal mountain of analysis of that 10w40 blend posted on that “Bobby’s oil forum” in different Diesel engines up to 12k miles.
It’s “add pack” not “add stock” smart guy. Group IV and V are always more desirable as they have better cold properties, lower volatility and superior resistance to oxidation. An lubricant that has expensive base oils doesn’t require a higher % of additives to get the same effect as an oil that uses cheaper bases like D1 Extreme.
Go ahead and continue to talk out your a$$ and tell us again how cheap Delvac Extreme is better than D1 ESP because you can’t read an SDS.
I don't know what my manual says. This was just a picture I foundYou've got a really old Owners Manual since it authorizes API CF-4 rated oil. Mine said CH-4. Now diesel-rated oil is CK-4.
But even then they recommended the 5w40 viscosity, and all 5w40 oil is diesel-rated and synthetic.
