mrchill
- Joined
- Sep 16, 2003
- TDI
- 96 B4v red \ 98 Mk3 green\98 Mk3 Jetta black\ 99 Mk4 Jetta green x2\ 99 Mk4 Golf silver x2\ 99 Mk4 Jetta black\ 97 B4 sedan green\04 JSW gold\03 JSW silver
So. Until recently, removal of a faulty or unwanted EGR cooler was easy and cheap....with no known repercussions. But some of us in CARB states have found that there is now a need for the EGR system to show active. A retune perhaps? Yes...but what about all those EGR parts you threw away? or were broken? Well. As long as you have an EGR\antishudder valve available to you, and you have a factory ALH intake manifold available or still installed, and of course an VNT15, VNT17, or hybrid 17\52(like IDparts.com sells) then you are in luck.
Part number 038 131 521 j is the bypass pipe from the factory for non EGR cooler cars (ALH type engine). This will take the place of the EGR cooler on any ALH engine with the aforementioned factory style parts. For the AHU\1Z crowd, naturally the 96 passat EGR pipe will work as these cars had no cooler. For the BEW crowd, I actually have two fixes in the works. I'll post when they are done. I have heard no complaints from the BRM folks about EGR, so I havent explored it as yet.
So, if you need a quick workaround, and you have a VW dealer near you, then have at it. The pipe is about 150 dollars. Not cheap, but cheaper than the cooler and the associated pipes...and MUCH easier to install.
