Dhawk12
I have an 02 ALH that is an auto to manual conversion (so 11mm pump) and it has injectors that I got from another manual engine without a tune that the owner said "were the biggest he could go without a tune". I did have to hammer mod to minimize smoke, there is almost none except for WOT runs.
It is a SMF (southbend) and a Sachs clutch of some sort that was on the donor car I pulled the trans from at the pick n pull. (Some photos I took when installed included)
It made it close to 4 years, but I think that clutch is going so looking for suggestions and sources for replacing in Canada.
Should I/ do I need to find another clutch for a SMF that can handle the slight bump in power, or should I just go back to the LUK DMF and will it handle the power? TIA
