Nozzleman
After 8 months not working on it, I finally got back on my Ranger a month or so back.
Trying to make the ALH PCM (Malone stage 4) talk to the aftermarket interface (tach, glow plug etc) via CAN-BUS.
I got the truck running but have an issue where the CAN-BUS shuts down after it runs for about 30 seconds. I have removed everything except the DLC port wires that is not required to make the engine run.
Got good power and ground and I get the proper tach signal out of the interface until it shuts off, yet the tach does not work. Swapped clusters and same thing. Turn the ignition the tach does its bounce, start it and it goes to idle rpm but won't move past that when revved.
Any ideas?
Thanks in advance.
Any ideas?
Thanks in advance.
