PDJetta
- Joined
- Nov 6, 2003
- Location
- Northern Virginia
- TDI
- '04 Jetta GLS TDI Pumpe Duce Platinum Grey w/ Leather
For timing belt replacement, the Bentley manual is unclear as to what part of the TDC mark you line up with the lower edge of the bellhousing window for an automatic transaxle with an ALH engine. The TDC mark is an oval "O" with two small lines on the outsides of the long side of the "O", in the center of the "O" and perpindicular to the direction of rotation. Do you line up the rear edge of the "O", or the two little lines that are at the center of the "O", with the rear of the bellhousing? The picture looks like it is the rear of the "O" you line up, but it would seem more logical for it to be the center of the "O", as indicated by the two little hash lines. Thanks.
--Nate
--Nate
