ALH #3 injector
brlau
Ontario
2001 golf 2013 Touareg
2 wire connector at #3 injector I have a broken black wire about six inches back from the plug in the harness. Any ideas on what this is from. Can’t see what it is supposed to be connected to.
97caron
Lookout
NB
Look at 3 injector at top white section. If broke that close to injector body you need new #3 injector. This is feedback to ecu of IP pump output.
brlau
Ontario
this is a wire back from the plug. Black I’ll try to post a pic
jmodge
Greenville, MI
2001 alh Jetta, RC2 5speed daily commuter and 2000 alh Jetta 5spd swap, 2" lift, hitch, stage 3 TDtuning w/502's backroad cruiser
If the two signal wires are intact, it probably is the shielding wire from that harness. It raps around the signal wires to avoid interference.
brlau
Ontario
brlau
Ontario
The blue and white wire are intact the black wire is stripped back not sure where it goes.
jmodge
Greenville, MI
It’s the shield so those signal wires don’t pick up any electrical interference, clean signal to the ecu that way. If it bothers you just tape over it. It’s irrelevant
