Ah - we are back again on the fumigation !
Yes, methanol and ethanol will work ..
.. ALSO fumigated diesel oil will work (this is documented in several SAE papers) !
The trick is that fuel / air mixture must be lean enough.
If the mixture is very lean those spontaneously oxidized fuel molecules do not release enought energy to cause a chain reaction (combustion).
Therefore a lean mixture will not combust in traditional way - regardless of the octane / cetane rating of the fuel.
What happens instead is a pressure and temperature induced cracking (long molecules are broken down and partially oxidized).
This cracking process is endothermic thus reduces the compression work.
Oxidation is exothermic and thus contribute to the expansion work.
Therefore it is possible to get the fumigated engine to run without combustion
(This has been demonstrated on some lab experiments ...)
And to the practical things ...
Alcohols can be fumicated simply by spaying directly to the intake. (Like water and alcohol/water -mixtures.)
This spraying cause some relatively large droplets to enter the combustion chamber. These droplets cause localized rich mixture areas. These rich areas may initiate the spontaneous combustion - but here the fairy high octane of alcohols help.
With diesel oil fumigation the problem is to have good homogenous lean mixture. (Because of the low octane - or high cetane - the mixture must be free from any richer mixture areas to avoid spontaneus combustion.) This lean mixture can be with heat evaporation or ultra fine misting (fogging). Heat evaporation simply works by heating the oil (boiling it directly or sparying a superheated fluid trough nozzle - The latter requires a high pressure heated injection system.) Fogging can be implemented with pressurized air ejectors or with ultrasonic (cavitation) fogging.
So the alcohol injection should be fairly easy to try out.
Oil fumigation might be worth to develope because no separate fuel is needed.
(Altough alcohol probably delivers more additional power trough evaporation charge cooling.)
