JoshWagen
Hey all - just replaced front pads and rotors on my 2015 GSW. Went with Zimmerman rotors and Akebono EURO ceramic pads. The pads fit extremely tight in the hanger - as in I had to wedge them into place and then mount on the rotor vs sliding them into place as I've done in the past. Using a ton of muscle, I could barely get them to slide back and forth on the hanger. I confirmed they are the correct part on ID Parts - EUR 1760. I cleaned the hanger properly with a wire brush. Pads were lubricated in all contact areas.
I compared them to the stock pads when I was having trouble even sliding them into place. I noticed the Akenbonos have a larger clip clearance compared to the OEM VW pads. It was obviously the problem with the tight fit. Has anyone had this specific issue?! Moreover, should I be concerned in general if I can't slide the pads back and forth on the hanger somewhat easy? Really don't want dragging brakes, and I'd like to replace ASAP if this will be an isse. Thanks for the tips!
