Ryder1032
Hey everyone. Having trouble with the lift pump on my 1999 Bora AJM TDI. Drove the car in the shop for floor work about a month ago, got ready to bring it out and now there’s no power at the lift pump harness. I had the fuel lines disconnected at the back of the passenger floor and had unplugged the harness so it wouldn’t pump fuel if I had the key on (added a sub amp with the carpet out and wanted to test it.) That was all I did to the fuel system and electrical.
I pulled the harness and tested for any voltage or signal while turning the key and got nothing. Put pins through the back of the harness and tested again with it plugged in and no difference. But, when I run a ground out of the harness and a lead off the sub amp constant 12v to the pump, it powers on so pump is fine.
After finding this out I found a detailed guide in here about testing them but after following that it didn’t lead me anywhere. I had checked fuse #28 and it was fine. I went to check the fuse in spot #10 and it seems that this car doesn’t have it. I can’t seem to find any wiring diagrams for this car regarding the fuel system either to see where the relay would be located or just to follow the harness. The only relays under the dash I have are:
Spot #1 relay #79
Spot #9 relay #53
Spot #12 relay #109
I’m absolutely stumped on what to do next but start pulling my interior again and tear apart the wiring loom and follow it to wherever it goes. If anyone can point me in a better direction id appreciate any help or advice.
Spot #1 relay #79
Spot #9 relay #53
Spot #12 relay #109
