Airbag light just came on...
brownnugen
Charleston, SC
2015 GSW TDI, 2011 JSW TDI & 2018 Atlas 2.0T S
2 nights ago, I tried to swap stock radios from a 2009 Jetta into my 2006 Jetta (following the step by step instructions from myturbodiesel) only to find out the 2009 radio is "tied" to the actual car and I would need the radio code for it to work. I decided it wasn't worth the hassle of trying to find the code so I put the stock radio from my 2006 back it.
Yesterday, I disconnected the car battery for about 3 hours to take my time and clean the terminals. I connected the battery back up without any issues.
This morning, when I started the car to go to work, the engine started right up but the airbag light came and stayed on. Would simply disconnecting the battery cause this or do you think me messing with the radio caused this?
Thanks in advance.
Spiked1Z
Austin, Texas
2006 Jetta TDI
I actually cleared mine with an android app and a Bluetooth obd2 reader, hasn’t come on since... probably not the best idea if you want to verify the airbag actually works... I just hated the damn light
Spiked1Z
Austin, Texas
2006 Jetta TDI
No disconnecting the battery should not affect the light, but who knows
robtechno
Hudson, NY
2015 Golf 2.0 TDI.Sport wagen 53K. Previously a Jetta 06 with 205K. A5-BRM,
I replaced my battery last week and after that my steering wheel airbag light came right on as well. 2006 TDI 194K
Carlos_TJ
Tijuana Mexico
2009 Bora (BXE PD)
Airbag codes will not disapear when disconnecring and reconnecting the battery. You need a scan tool to read, fix whats broken and then clear the code
Scan tool will tell you why the light is on faster than it took to make this thread.
It is always possible that a low voltage condition happened at some point, but who knows.
It is 100% normal for the steering wheel and anti-skid lights to be on after the battery is disconnected, though. I quick drive and turning the wheels will reset that. That has nothing to do with the SRS.
bagger
AZ, USA
My current Jetta 2009, Blue. My first Jetta 2002,Blue.
Will VCDS tell you what sensor failed. I know there are a bunch of things that will turn light on. Is there a list of faults somewhere?
325_Guy
West Central Texas
MkV Jetta
Will VCDS tell anyone this thread is ~7 years old? :p
Probably not!
But in case the OP or anyone else is wondering, the OPs airbag light came on in response to disconnecting the passenger airbag indicator light as part of the stereo system replacement.
Yes, it's just an indicator light, but its proper functioning is monitored and requires VCDS or equivalent to clear.
bagger
AZ, USA
Probably not!
bagger
AZ, USA
Well y’all were right again. VCDS says passenger side rear crash sensor fault. Disassembled and found rats nest with the wires chewed. Easy fix and airbag light is out. Thanks to all who helped.
