I have replace two AIRBAG ( LENKRAD - PASSENGER ) THREE mounth ago.
Sunday I had replace the Airbag Control Module ; but the light still is on my dashboard.
I know that I must change the CODING with VAG-COM (but I can't ! because my Hex-Can interface did not work anymore)
So I replace the OLD Airbag Control Module but when I try to reconnect it ....the two front AIRBAG EXPLODED!!!!!
Then I have to replace the two front airbag , I have two Airbag Control Module (the damaged one - a new one)
These are the error when the VAG working good.
Address 15: Airbags
Part No: 1K0 909 605 D
Component: 01 AIRBAG VW8 022 0600
Coding: 0012337
Shop #: WSC 01371
5 Faults Found
01217 - Side Airbag Igniter; Driver Side (N199)
002 - Lower Limit Exceeded
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
001 - Upper Limit Exceeded
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
01588 - Igniter for Head-Airbag; Drivers Side (N251)
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Do you think I have to go to VW or I can try to fix ( with two new AIRBAG and a new AIRBAG MODULE )?
Address 15: Airbags
Coding: 0012337
Shop #: WSC 01371
5 Faults Found
