2000 Beetle TDI
I removed the passenger seat to haul some stuff, after re-installing it, the airbag light came on.
I have a registered version of Vagcom Lite with the dreaded 3rd party interface BUT it works fine.
I pulled up the airbag fault codes and got the first 3 shown below, tried to clear the codes to no avale, then like a quite possible dumbass, I disabled the PS airbag in settings.
Now there are 4 codes, the 4th being no communication with controller (airbag)
Did I brick it ?? .......... codes below;
00532 Supply voltage B+
07-10 Signal to low - intermittent
01218 Side airbag ignitor Passenger side (N200)
32-10 Resistance too high
65535 Internal control module
Memory error
---------- after disable--------added this code to the previous 3
01299 Diagnostic interface for
data bus (J533)
49-00 No communications
Memory error
data bus (J533)
