silverbox
Air lift users do you tee them together or have seperate lines?, I'm leaning toward seperate lines.
Resurrecting a dead thread..uberdiesel said:I T'd my lines and brought the single piece to the back and secured it with the schrader air valve extending downward out of the rear passenger side valance. At the top of this thread dieselprogrammer shows a clever way of putting the valves in the fuel filler area.
weasel said:Ya, there is definitely struts back there ... Air struts maybe ?? Only thing I can think of that will just drop right in.
I have a target lead acid compressor that would handle this and does the tires quite nicely. Cost $35 with metal valve and generous battery life, sometimes those chinese products hit the mark as much as I hate to admit it. My Jetta has a charging plug in the trunk for it... It won't handle handle 80 PSI in the truck in any sort of reasonable amount of time, though nor is it as cool as having a dash switch.cbass94 said:Has anyone looked into setting up a small air compressor with this kit? It seems that an ARB air compressor like the kind that is used for air lockers in differentials would work perfectly. I just wonder if it would pump enough air though.
Air lift makes one that has a low pressure regulator so the bags will never drop below 5-10 PSI, you can set it (hobbs switch) to what ever you want.cbass94 said:Has anyone looked into setting up a small air compressor with this kit? It seems that an ARB air compressor like the kind that is used for air lockers in differentials would work perfectly. I just wonder if it would pump enough air though.
I haven't used mine under pressure in the cold; sorry I can't help.jackbombay said:Are any of you guys having issues with the fitting leaking at the air bag
with cold weather? I sure am, the compressor runs every 30 seconds or so :-/ I pulled the fuse to stop it.
What brand did you go to?DPM said:I lost two airlift bags; they both hardened and then cracked. Both failures were at around freezing temps, nothing extreme. The first was replaced under warranty and I went to a different spring setup after the second.
Is this to say that the Air Lift 80753 kit can not be used below freezing temperatures? That would be a bummer... I was really interested in ordering it from Summit Racing.DPM said:I lost two airlift bags; they both hardened and then cracked. Both failures were at around freezing temps, nothing extreme. The first was replaced under warranty and I went to a different spring setup after the second.
Mine leak like giant holes in the winter, I have yet to use them this summer as they were leaking SOOO BAD last winter that I can't believe they could possibly hold air now, it does get COLD here, -30*F. Airlift says there should be no cold weather issues, fwiw.NarfBLAST said:Is this to say that the Air Lift 80753 kit can not be used below freezing temperatures? That would be a bummer... I was really interested in ordering it from Summit Racing.
Without removing the springs you would need a giant pile of beer and swear words to get the air bags installed, it is really a lot easier and quicker to just remove the lower shock bolt and remove the spring, support the axle with a floor jack when you remove the spring as the shock does hold the spring compressed a bit.NarfBLAST said:Also, it is possible to install the kit without removing the springs?
Thorne said:Looks like a great solution for the rear, but what about the front? I need the clearance there also, particularly if the rear is raised...
I'm guessing my options for front lift are either the Metalnerd setup or possibly later-model Jetta VR6 springs?
