BuckeyeMan71
I have a 2003 wagen that the compressor clutch won’t spin. Chilton manual shows I can jumper pins 1&2 on a 4 pin plug but mine is a 3 pin plug. Or is there a way I can do it with my VCDS? Thank you in advance.
It's not a switch, it's a sensor which outputs a signal proportional to system pressure. Jumpering the sensor would serve no useful purpose.I was referring to the pressure switch up by the firewall. It’s a 3 pin
... it will actually blow the fuse for the fan control module I think.It's not a switch, it's a sensor which outputs a signal proportional to system pressure. Jumpering the sensor would serve no useful purpose.
Which one am I looking for? He has a lot of them. I tried just hooking a can up to it and it wouldn’t kick it on. I was also wondering how likely the pressure switch is to go bad. Also both fans do come onYou should check out DanG144's thread, it will have some good troubleshooting for the HVAC/cooling system.
On a 2003, the fans should BOTH come on LOW speed if the A/C is switched on, even if the engine isn't running (so long as the key is on).
I’ve checked all my fuses but have not checked clutch resistance yet as I haven’t been able to get it up under it to do so.Have you checked fuses or clutch coil resistance yet? Those are by far the most likely culprits given the fans run.
