Your compressor is not supposed to "cycle on and off".
Maybe I'm using the wrong terminology. I just know that the vibration comes and goes, intermittently, when the A/C is on. This started happening right after I got the compressor and dryer replaced. The expansion valve was replaced before when we thought the expansion valve was broken, but later turned out that the compressor itself was busted.Your compressor is not supposed to "cycle on and off".
So I will ask one more time.Do yourself a favor: your Volkswagen was equipped from the factory with a Sanden compressor, a Parker drier, and usually either a Valeo or Hella expansion valve. If any one of those pieces is NOT the above mentioned brands, replace it with one that is. Your local dealer of course can get all the correct stuff, but many aftermarket places can also get the proper stuff. Then, once Volkswagen parts are installed, your Volkswagen's A/C system will once again function they way it is supposed to.
Agreed 100%. That is ALL I am trying to say. For some reason these idiots don't see that.Everyone, please let's just drop the whole "Chinese" part and "Chinese" race back and forth posts. I am of Chinese ancestry and I have no problem using any part, made in any country, made by any people, as long as it performs up to spec. If the parts that were installed were inferior, let's just call it that and leave people/nation/race out of it.
Case in point: my Golf was designed in Germany, assembled in Brazil, and uses parts from all over the VW supply chain in Europe.
Has this car had its troubles? Yes. Do I sometimes think VW parts fail prematurely (window falling (cheap plastic retainer clip), fuel pump replacements, failed 01M transmission, LCA, drive axel, water pump, thermostat, etc.)? Yes.
Am I going to start blaming bad German design, bad Brazilian assembly, poor quality Spanish parts, etc.? No.
I have a problem with my A/C. Can we please just focus on the problem at hand?
Thanks.
Alex
Are you for real, dude? Could you be any more insensitive or racist? HOLY CRAP!!!![]()
<deleted>
Good idea. I will craw under the car later tonight and see if the pullet is loose.alex_tdi,
I don't mean to get off the "where are the parts from" subject but I am more interested in what is causing your vibration from seeing your video.
Have you looked under the hood at your serp. belt and your A/C pulley to see what my be causing the vibration when it begans to cycle? Maybe the pulley is loose and starts to wobble, let us know.
Very interesting noise it's making in that video. Sounds serious but I have no idea what it could be.http://www.youtube.com/watch?v=gMA5VVHh8xo
DING DING DING! We have a winner!I can't wait to see how this plays out ^^^
Oilhammer is a great person and has contributed more to this automotive community than about any other single person on this site.
If you are offended by his comments, too bad for you. How dare you try to be the PC police here. Last I checked 16VJohn, you are not a moderator here.
If anyone is offended by Oilhammers comments here, just overlook them and value the mechanical advise he provides. If you are offended by what you read from him, spend about 30 minutes in southern Mississippi and see how African Americans (sorry, was I just racist ?) are treated and what they are called on the street.
If you think his comments are racist you need a reality check. He is talking about inferior quality parts, not people. If you find Chinese made parts acceptable for your car, feel free to buy your parts from the lowest priced vendor you find on Ebay.
Grow up or go away.
An undercharged system will result in an icing evaporator quite often due to uneven refrigerant distribution, BUT THE OVERALL COOLING PERFORMANCE IS LESS. So if you start the AC up with proper airflow and a clean air filter, and right off the air temperature is below freezing, then it sounds as if the compressor is overcooling. Someone else here talked about variable displacement being a need for this car.OK, so I went to the mechanic today and we confirmed that the air coming out of the vent was below freezing! (-1.2 degrees C). The plan was then to adjust the freon (R-134) in the system.
The first time he hooked up the car to the machine that he uses to charge / discharge the A/C, the pressure was reading around 40 psi on low and about 100 psi on high I think. He was going to recharge the system, but he said that he freon might have frozen up so we turned off the engine and let it sit for a bit. After about 10 minutes, he reconnected the machine to the car and there was no pressure reading at all.
After trying a few times he looked at the line valve (both the high and low) and he said that the rubber inside the valve was bulging out so they had to be replaced. A quick call to the dealer revealed they were $43 each! He said that the American and Japanese cars uses a metal pin style valve that he has plenty of, but he doesn't have any for VWs so he has to special order from the dealer.
So now I'm looking at spending another $100 bucks on two line valves that really don't get used much, so I don't understand how they could fail so easily.
Is this simply a case where the mechanic is not familiar with how VW parts look like? We don't have another VW to compare it against for reference.
Do you guys think I can use the other style valves? A/C has been around for so long, I find it hard to believe these parts aren't standardized yet. Or do you think they be fixed somehow?
Thanks.
Alex
Here are the parts in question (low side valve = 13, high side valve = 12):
This poster sounds like he may have hit the problem. If the airflow is at spec and the air is that cold right away, then the compressor is overcooling. Overcharging does not cause overcooling, that is a myth. Overcharging drives up the condensing pressure on TXV regulated systems, lowering efficiency. On a cap tube AC unit, over-charging can squeeze a tiny bit more cooling, but the bigger concern then is "floodback" where liquid can get into the compressor and destroy it.This AC system is a beast, 7kW compressor with a maximum CoP of 2.2 means it is a 4 ton unit. That is enough refrigeration to cool a 2400 square foot house in the SW USA. It needs the variable displacement compressor, the proper receiver-dryer and the electronic controls/sensors to operate properly.
Replace the compressor with a fixed displacement compressor in the 150 cc/rev range and it will ice the evaporator. Plus the pressure limit switch will cycle the compressor, causing idle issues. IIRC, the stock specification Sanden compressor has a variation of 10:1 with a max displacement of ~160 cc.
I don't see any issues with knocking inferior Chinese goods. After WWII, Japan adopted the Deming Model, turning their industries into wold class operations. That Sanden compressor? Japanese design at the least.
Hi Oilhammer.. Sorry I am digging up this old post.. I got my A/C compressor reconditionned.. I just wanted to confirm: The compressor is not supposed to cut off if the evaporator temperature drop? Let's say around 4-5 degrees?Your compressor is not supposed to "cycle on and off".
Hello Stone 14,Hi Oilhammer.. Sorry I am digging up this old post.. I got my A/C compressor reconditionned.. I just wanted to confirm: The compressor is not supposed to cut off if the evaporator temperature drop? Let's say around 4-5 degrees?
The problem I am having is that my evaporator is freezing up and blocking the air at some time![]()
All I'm getting from this is that some folks are easily offended by facts.Huh? Can you remind me where I said anything about all Asians being from China or Japan? ... or Mexicans, Latinos, Vietnamese or Koreans?I'm really trying to figure out what kind of point you're trying to make here besides proving to me how useless you really are. Who is it that needs to get a life here? You've added nothing to this thread but offend me and tell the OP that the parts he just bought should be immediately removed and replaced with OEM without knowing one single fact about them other than the evap is freezing over... Just exactly how much are you trying to take away from this thread? I'm trying to help and you are really just a parasitic drain. It's incredible how long they have allowed your incoherent ramblings to go on. Wow, just wow.
Good advice.. Will do some more research thenHello Stone 14,
Just some friendly advice, read and study the sticky on this forum about radiator fan operation and A/C troubleshooting from DanG144 before going any further.......and thank you for bringing up this old post....... I was bored and needed a bit of high entertainment this Sunday afternoon!![]()
As he said, it does NOT cycle off and on. It's always on, but the compressor uses a RCV - refrigerant control valve, to regulate the compressor in producing the correct freon flow;. I am pretty sure the RCV uses the fan setting to modulate this.Hi Oilhammer.. Sorry I am digging up this old post.. I got my A/C compressor reconditionned.. I just wanted to confirm: The compressor is not supposed to cut off if the evaporator temperature drop? Let's say around 4-5 degrees?
