air circ damper...I think
casteld73
Orange County NY
Jetta '06 TDI
I have an 06 TDI Jetta. Every time I start the car I hear a buzzing noise under the glove box. It lasts for about 5 seconds---feels like 3 minutes.
I can easily replicate the noise by pushing the recir air button on my air control. Also I noticed when I put the car in reverse it also triggers it.
I mentioned it to the dealer (who managed to rotate my tires and crank the lug nuts with about 400ft-lbs of torque) that the car was making the noise (out of warranty). They told me it is a major project and would cost over $1K.
Has anyone else experienced this problem. My guess is that it is the actuator or something like that on the damper...not quite sure how it works.
Just curious if there is an easy fix. 92Kmi and this is my first "problem". Not bad.
TIA
Lug_Nut
Sterling, MA. USA
2015 GSW 6M in S trim the other oil burners: 1967 two stroke Sonett 1988 Bolens DGT1700 1962 Quantum III
Apparently you're the first.
The earlier (10+ years ago) air supply flaps were operated by a solenoid valve under the hood that could rust and stick in one position, but no noise, and definitely no ability to duplicate by selecting reverse gear.
rex_1_mn
SW MN West of Marshall....
05 PD Golf GLS Manual
Not sure what is causing the noise but it does it when you put it in reverse because the car automaticly goes into recirc in reverse to keep you from sucking in fumes while backing up....
Its kinda cool... Wish I could offer more help..
casteld73
Orange County NY
Jetta '06 TDI
I was going to try and disassemble dash by glove box....Has anyone done this..am i in over my head. From under the hood I could not locate the problem
