1998 jetta TDI with AHU
Looking to put in a VNT17 and wondering where the vacuum lines should go. I have attached the vacuum diagram for an AFN motor. What is necessary and what can be omitted?
Current setup
1749VC
PD150 intake manifold
AFN exhaust manifold
Rocketchip tune with 3 bar map sensor
.216 nozzles
2 1/2" downpipe straight exhaust
I was looking through the diagram below, it seems like there are 2 N75 valves, I will not be using an EGR so I was thinking I could remove that section of plumbing. Also, are the vacuum reservoir and check valve necessary? Any advice would be appreciated. Thanks in advance.
Current setup
1749VC
.216 nozzles
