davidgylland
I have read at more then one place that the GQ ecu was used in a service campaign to eliminate the 5th injector.
i have seen the following thread https://forums.tdiclub.com/index.php?threads/96-passat-ecu-with-last-2-letters-bk.83021/
however I unsure, how to proceed. do anyone know why my vehicle would have these codes with the ecu I have? I have confirmed the wiring does not have the pins for the components required for the items identified in the codes.
VCDS-Lite Version: Release 1.2
Friday, 04 February 2022, 18:34:35:64425
Chassis Type: 3A - VW Passat B4
Scan: 01,02,03,08,15,25,41
Address 01: Engine Labels: 028-906-021-AHU.LBL
Controller: 028 906 021 GQ
Component: 1,9l R4 EDC G00SG 1420
Coding: 00002
Shop #: WSC 04722
VCID: 64BBD43AE743
2 Faults Found:
00310 - CAT Temperature Sensor 1 (G20)
30-00 - Open or Short to Plus
00309 - Washer Solution Metering Pump (V135)
31-10 - Open or Short to Ground - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 3A0-907-379.LBL
Controller: 3A0 907 379 A
Component: ABS/EDS ITTAE 20 GI V00
Coding: 04505
Shop #: WSC 00000
VCID: 2823800ADBEB
No fault code found.
Address 15: Airbags Labels: 6N0-909-60x-VW2.LBL
Controller: 6N0 909 603 G
Component: AIRBAG VW2 V00
Coding: 00071
Shop #: WSC 05311
VCID: 361F5E72015F
Coding: 00002
Shop #: WSC 04722
VCID: 64BBD43AE743
2 Faults Found:
Readiness: N/A
Coding: 04505
Shop #: WSC 00000
VCID: 2823800ADBEB
Coding: 00071
Shop #: WSC 05311
VCID: 361F5E72015F
