mrbowtieguy
I broke the center of the three bolts that hold the mount on the transmission. first I tried to weld a nut onto the bolt that was left protruding no luck. I went ahead and drilled the bolt out to try an extractor no luck. I finally drilled the bolt out any ideal on how to get the treads of the bolt out? or would it be OK to drill the treads out and install a grade 8.8 nut on the back side?
