this is what I have,
Thursday,02,June,2022,08:11:33:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: 3VWPL7AJ4CM682160 License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 56 62 72
77
VIN: 3VWPL7AJ4CM682160 Mileage: 248610km-154479miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
1C-Position Sensing -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
2E-Media Player 3 -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 E HW: 03L 907 309 AA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H14--- Serial number:
Coding: 0050078
Shop #: WSC 49260 001 1048576
VCID: 306FA5C7A3235A0B73-8064
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 062 B HW: 02E 927 770 AL
Component: GSG DSG AG6 512 9430
Revision: 05551213 Serial number: 00001201281511
Coding: 0000020
Shop #: WSC 00066 000 00000
VCID: 14270957377B862B77-8040
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 114B600C492A00FC880C06EA92190042B70000
VCID: 7DF14CF3E4F16763A8-8028
8 Faults Found:
01314 - Engine Control Module
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Mileage: 454509 km
Time Indication: 0
Date: 2016.09.25
Time: 17:35:10
Freeze Frame:
Count: 2
Count: 12
Count: 4608
Count: 8194
Count: 41984
Count: 0
Count: 1030
Count: 0
00285 - ABS Wheel Speed Sensor; Front Right (G45)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 154
Mileage: 454509 km
Time Indication: 0
Date: 2016.09.25
Time: 17:46:14
Freeze Frame:
Count: 7
Count: 13
Count: 4608
Count: 51
Count: 25600
Count: 0
Count: 265
Count: 0
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 154
Mileage: 454509 km
Time Indication: 0
Date: 2016.09.25
Time: 17:46:14
Freeze Frame:
Count: 7
Count: 13
Count: 4608
Count: 35
Count: 25600
Count: 0
Count: 265
Count: 0
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 154
Mileage: 454509 km
Time Indication: 0
Date: 2016.09.25
Time: 17:36:31
Freeze Frame:
Count: 7
Count: 13
Count: 4608
Count: 128
Count: 28160
Count: 0
Count: 253
Count: 0
00667 - Ambient Temperature Signal
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 156
Mileage: 454563 km
Time Indication: 0
Date: 2016.10.03
Time: 06:19:48
Freeze Frame:
Count: 0
Count: 12
Count: 20480
Count: 8259
Count: 45824
Count: 0
Count: 253
Count: 0
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 156
Mileage: 454563 km
Time Indication: 0
Date: 2016.10.03
Time: 00:02:59
Freeze Frame:
Count: 0
Count: 12
Count: 20480
Count: 8208
Count: 45568
Count: 0
Count: 253
Count: 0
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 162
Mileage: 454509 km
Time Indication: 0
Date: 2016.09.25
Time: 17:35:19
Freeze Frame:
Count: 16386
Count: 12
Count: 4608
Count: 16390
Count: 43009
Count: 0
Count: 262
Count: 5120
02214 - Tire Pressure Warning
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 165
Mileage: 453301 km
Time Indication: 0
Date: 2016.03.11
Time: 07:20:11
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 16401
Count: 50944
Count: 255
Count: 65276
Count: 0
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0404
Revision: 00001016
Coding: 0000001002
Shop #: WSC 00066 000 00119
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 000F35079B030A8BC3-8054
1 Fault Found:
13701456 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 3
Reset counter: 156
Mileage: 454563 km
Date: 2022.05.13
Time: 00:02:58
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 J HW: 5K0 937 084 J
Component: BCM PQ35 B 021 3068
Revision: BG021001
Coding: 2F380E1F802F3EC4008800C17000004449000086535D0560648020200040
Shop #: WSC 28044 001 1048576
VCID: 397998E3B0599B43C4-806C
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 17031 26 0512
Coding: 009795
6 Faults Found:
00526 - Brake Light Switch (F)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 155
Mileage: 454531 km
Time Indication: 0
Date: 2016.10.03
Time: 02:35:29
Freeze Frame:
Term 15 On
Voltage: 9.45 V
ON
ON
OFF
OFF
ON
00927 - Terminal 30 (Right)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 165
Mileage: 248577 km
Time Indication: 0
Date: 2016.10.23
Time: 09:52:42
Freeze Frame:
Term 15 Off
Voltage: 12.80 V
OFF
ON
OFF
OFF
OFF
00984 - Left Tail Light (M4)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 165
Mileage: 248437 km
Time Indication: 0
Date: 2016.10.23
Time: 08:06:47
Freeze Frame:
Term 15 Off
Voltage: 12.60 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 155
Mileage: 454531 km
Time Indication: 0
Date: 2016.10.03
Time: 02:35:31
Freeze Frame:
Term 15 On
Voltage: 9.30 V
ON
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 156
Mileage: 454563 km
Time Indication: 0
Date: 2016.10.03
Time: 00:02:59
Freeze Frame:
Term 15 On
Voltage: 12.80 V
ON
ON
OFF
OFF
OFF
02746 - Bulb for Daytime Running Light; Right
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 247
Mileage: 434163 km
Time Indication: 0
Date: 2014.09.07
Time: 00:08:32
Freeze Frame:
Term 15 On
Voltage: 14.05 V
ON
ON
OFF
OFF
ON
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA1HEWM
Coding: 00003133
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3F8DF6FBA67DB573FA-806A
Seat occupied recognition:
Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--000038N600
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME025B6368ZZZY
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME75763569ZZZ%
Rear Side Airbag Crash Sensor (on driver's side):
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME141D3C2BZZZS
Passenger side rear thorax airbag crash sensor:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME2D273C2BZZZY
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME01036929ZZZ6
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME016F4028ZZZD
5 Faults Found:
12670208 - No Communication with Instrument Cluster
U0155 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 156
Mileage: 454563 km
Date: 2022.05.13
Time: 00:02:58
13635840 - Supply voltage
U1011 00 [008] - Voltage too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Mileage: 454509 km
Date: 2022.05.05
Time: 17:37:22
12674816 - Immobilizer Control Module
U0167 00 [008] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 156
Mileage: 454563 km
Date: 2022.05.13
Time: 00:02:58
9483264 - Seat Occupied Recognition
B10B4 00 [008] - Function Restriction due to Undervoltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 155
Mileage: 454509 km
Date: 2022.05.05
Time: 17:36:38
9483008 - Seat Occupied Recognition
B10B3 00 [008] - Function Restriction due to Implausible Message(s)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Mileage: 454509 km
Date: 2022.05.05
Time: 00:03:57
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422LB6000XO
Coding: 188A140000
Shop #: WSC 00066 000 00187
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76E353DFC9C7343BE9-8022
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Serial number: 0105428
Coding: 820000
3 Faults Found:
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 153
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
136194 - Supply voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Mileage: 454509 km
Date: 2022.05.05
Time: 17:36:22
147464 - Terminal 15
B1148 29 [008] - Signal Implausible
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K0 920 972 C HW: 5K0 920 972 C
Component: KOMBI H03 0607
Serial number: 00000000000000
Coding: 270F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 306FA5C76B235A0B73-8064
2 Faults Found:
12648448 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 153
Mileage: 454509 km
Date: 2022.05.05
Time: 17:35:10
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 153
Mileage: 454509 km
Date: 2022.05.05
Time: 17:36:22
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 P HW: 1K0 907 951
Component: J533 Gateway H40 1623
Revision: H40 Serial number: 09031201290915
Coding: 352002
VCID: 3D718CF3A471A763E8-8068
1 Fault Found:
00381 - Databus Instrument Cluster
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 156
Mileage: 454563 km
Time Indication: 0
Date: 2016.10.03
Time: 00:02:59
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223RG7B606
Coding: 0000002
VCID: 7EF34BFF29F77C7BB1-802A
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 156
Mileage: 454563 km
Time Indication: 0
Date: 2016.10.03
Time: 00:02:59
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0607
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADB77AF8D7FE0DB7D-803E
1 Fault Found:
9456681 - Key
B104C 29 [008] - Implausible Signal
Freeze Frame:
Fault Priority: 6
Fault Frequency: 9
Mileage: 400141 km
Date: 2019.06.20
Time: 20:30:17
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7661503461
Coding: 010000
VCID: 295948A340F92BC3B4-807C
2 Faults Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 153
Mileage: 454509 km
Time Indication: 0
Date: 2016.09.21
Time: 16:16:56
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Mileage: 454509 km
Time Indication: 0
Date: 2016.09.25
Time: 17:36:23
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0004154677
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW36.rod
VCID: 5BB5226B52258953F6-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 007 1509
Serial number: 00000006360207
Coding: 000490
2 Faults Found:
66048 - Motor for Front Window Regulator
B11EC 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 156
68102 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 156
Mileage: 454563 km
Date: 2022.05.13
Time: 00:02:58
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 N
Component: EPS_ZFLS Kl. 70 3301
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 356194D35C417F2320-8060
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 155
Mileage: 454531 km
Time Indication: 0
Date: 2016.10.03
Time: 02:35:30
Freeze Frame:
Voltage: 9.50 V
PD
Temperature: 23.0°C
RPM: 1498 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 156
Mileage: 283567 km
Time Indication: 0
Date: 2016.10.03
Time: 00:00:29
Freeze Frame:
Voltage: 12.75 V
DD
Temperature: 61.0°C
RPM: 0 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1623
Coding: 050B0500
VCID: 6FED66BBBE9D05F32A-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H03 0220
Serial number: 0123456789ABCDEFGHIJ
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H03 0220
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0004198303
Coding: 0004B4
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
VCID: 5CB72177572B8E6BFF-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 007 1509
Serial number: 00000006339113
Coding: 000490
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 156
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 156
Mileage: 454563 km
Date: 2022.05.13
Time: 00:02:58
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7M3265516
Coding: 01000400040007
VCID: 63C51A8B6255B193BE-8036
3 Faults Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 44
Reset counter: 122
Mileage: 343131 km
Time Indication: 0
Date: 2012.08.23
Time: 00:44:17
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Mileage: 454509 km
Time Indication: 0
Date: 2016.09.25
Time: 17:36:23
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 156
Mileage: 454563 km
Time Indication: 0
Date: 2016.10.03
Time: 00:02:59
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H12 2902
Revision: 1B001001 Serial number: 00007661781837
Coding: 0A10040000010100
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA_A01_VW25.rod
VCID: 275D4E9B5EED1DB3A2-8072
3 Faults Found:
U0155 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 156
Mileage: 454563 km
Date: 2022.05.13
Time: 00:02:58
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Mileage: 454509 km
Date: 2022.05.05
Time: 17:36:22
13893632 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 153
Mileage: 454509 km
Date: 2022.05.05
Time: 17:36:22
