AFN only goes into limp mode up a certain hill in 2nd gear
Minimim
Slovenia
1.9 TDI AHU, 1.9 TDI AFN
Hello everyone! So if you dont like to read skip to the next part.
I purchased my Golf mk3 1.9TDI AFN a few months ago for cheap. I did some body work and got it looking like a car again. Also did a lot of engine work: Oil, filters, belts, rollers, tensioners, fuel hoses, vacuum hoses (also the one inside the ECU), some gaskets and whatnot. The main thing was i cleaned the VNT turbo because the car was undrivable. Went into limp mode in the driveway before cleaning it. After cleaning it the car was drivable again and it has plenty of power through the entire rev range on a flat road and uphill. Does whatever i ask it too. Also added heated and cooled and some other stuff for my comfort.
So the issue is that when i go up my last hill to get home (about a 17 degree incline for 250m). In 3rd the car smoothly glides up the hill while still being able to gain speed. However when i go up the hill in 2nd gear and have about 1/4 throttle it sometimes (not always) goes into limp mode. Highway 5th gear, full throttle, 160km/h no limp mode so i would guess its not over boosting. One thing to note is that i didnt check/adjust the VNT actuator because i dont have a mighty vac. It moves by hand and does not bind. Actuation test it also moves until the vacuum runs out. All connectors were cleaned and inspected. Below are the links for my MAF, MAP and N75 duty cycle logs. This is where my knowledge lacks because i dont know whats good and whats not. I wouldnt want to throw parts on it but i suspect the N75 is acting up because of the long duty cycle it had. I couldnt get it to go into limp mode on my log. The glow plug light does not turn on when it does go into limp mode but the code it gives me is
00575 - Intake Manifold Pressure: Control Difference Intermittent
One think to note also is that i changed the timing belt about 6000km ago and the timing is on the green line (right on the edge of advanced). I adjusted it like this so that the belt stretches it goes towards the retarded side. Could slightly advanced timing also cause this?
THANKS IN ADVANCE!
MAP
N75 Duty
MAF
Minimim
Slovenia
Car is overboosting! Could be sticky vanes or just a dying N75…
I doubt its the vanes since i gave them a good cleaning and i can move the actuator with my fingers stop to stop. Ill see if i have a used N75 and swap it to see if it will be the same, worse or better.
thechoochlyman
Campbellsville, Kentucky
1997 B4 Sedan
I've had similar issues in my AHU Passat. For me, cleaning out the wastegate actuator basically fixed it. I sprayed it out with engine degreaser via the little straw on the can and then compressed air several times. You wouldn't believe what came out. I also replaced all the vacuum lines which helped, and tried a new N75.
Minimim
Slovenia
So a little bit of an update. I didnt have so much free time to work on my Golf so i just lived with the limp mode and didnt use 2nd gear on hills. 2 days ago a friend was about to scrap a 90s Polo and i asked him if i could part it out. It had an N75 for the EGR so i swapped it with mine and cleared the ECM code. Did a 800km trip this weekend and so far so good. On the big hills it doesnt go into limp mode and it also reacts a bit quicker when i have cruise control enabled.
Also fixed alot of rust holes on the doors and hatch so the car will be ready for next week when i (hopefully) get my full drivers license.
Im very happy with the car so far. Way better to drive then my 2.0 Clio sport but thats more of a weekend toy.
garciapiano
Los Angeles
1997 Jetta TDI (1Z)
The N75s can fail internally in such a way that they don’t have the “oomph” to open the wastegate. Basically the solenoid leaks.
