50harleyrider
- Joined
- Jun 16, 2007
- Location
- charleston,wv
- TDI
- 2005 B5.5 TDI/geared BSM, BV43A turbo,stage 2 TDTUNING. 2005 5sp manual passat tdi stage 2 tdtuning,BSM delete. 2015 Passat TDI 6sp manual.
I'm getting a GMR prepped to put in a sedan and wanted advice on what I should do to prep it first. It has 210k miles on it and was code free in VCDS when I pulled it. The engine had a catastrophic bsm failure so I didn't get a chance to test it on the road. My plan is to change fluid and filter and just install it. As most of you know, this big tranny is not an easy install so I don't want to pull it out again if I don't have to. I don't see any seals leaking either.
