Additional CCM coding and configurations with VDS Pro
Mozambiquer
Versailles Missouri
Hello Mozambiquer, can you please let me know how you managed to do it? Thank you so much in advance!
For the hatch unlock on my Golf I changed bit one on addresses 04280,04286 and 04292 to zero, going, in my case from decimal 204 to 76 and that enabled the hatch unlock with the doors. I am not sure if the Passat and Jetta wagon are the same.
Nuje
Island near Vancouver
...and this was on a 2001 car?
If so - that's GREAT information! Friend's 2001 car with manual windows and we were trying to get the hatch unlock to work, but I didn't know to look at those addresses. Will give it a try for sure.
Mozambiquer
Versailles Missouri
Yes, that was a 2001 Golf. I'm not sure if jetta or passat are different, and also not sure if the one with manual windows will be any different.
Obviously the number returned may be different
BananaOne
NH
none
Does anyone have a backup of the CCM EEPROM values for a 1C0959799 CCM in a 2002 4-door golf? Specifically addresses 4352-4372. I was trying to get the hatch to unlock with doors and now have several oddball problems with my alarm, locks, and lights.
Stagsboy
England
Hi,
Here are the values from a 1CO959799B (01X) CCM form my 2003 5 Door Golf.
04352 08
04353 08
04354 08
04355 88
04356 88
04357 88
04358 10
04359 10
04360 10
04361 02
04362 02
04363 02
04364 BC
04365 BC
04366 BC
04367 30
04368 30
04369 30
04370 04
04371 04
04372 04
The 02 Value in 04361, 04362 and 04363 is windows roll up/down via remote Fob. All others are stock.
Hope that helps
BananaOne
NH
none
Hi,
04352 08
04353 08
04354 08
04355 88
04356 88
04357 88
04358 10
04359 10
04360 10
04361 02
04362 02
04363 02
04364 BC
04365 BC
04366 BC
04367 30
04368 30
04369 30
04370 04
04371 04
04372 04
Hope that helps
Thank you! Are those values all in hex or are some in decimal?
mihau9999
Poland
B5.5 1.9TDi
Hi. I have a problem. Passat B5.5 Wagon, 1C0 959 799B
I try to activate trunk open via remote. Changed 04361-3 from 75 to 68, and 04367-9 from 255 to 253. Now i can't open trunk from outside, VCDS shows fault code: 01141 - Luggage Compartment Unlocking Switch (E165) 27-00 Implausible Signal . I'm go back to previous values, but nothing. I can't open trunk. Is this possible? Any ideas?
SilverGhost
Back in So Flo - St Lucie
'05 Golf - totaled :(, wife's '13 Beetle - buy back, TDIless
Off the top of my head - some CCM require a reset for coding to take effect. You may have to lock it for a hour and try again. Or disconnect battery for 1/2 hour and retry. Sometimes these CCMs don't like change.
Jason
321thijs123
The Netherlands
T5 Multivan 2.5 TDI 174hp 4Motion Highline, Golf Mk4 1.4 16v
Hi,
I have retrofitted my golf mk4 with power windows.
I used a 1C0959799F CCM from a seat leon, this allowed me to still use my old 1j0 style speed, door open, and ignition signals.
I changed these bytes (decimal) to enable remote windows and the alarm.
Code:
Remote window activation
04361: 10 -> 2
04362: 10 -> 2
04363: 10 -> 2
Alarm activation
04355: 17 -> 16
04356: 17 -> 16
04357: 17 -> 16
This both functions fine now, but I still have two remaining problems:
  1. My car doesnt have a sunroof but the ccm thinks it's open (Does this have any concequences?).
  2. When locking the car immediately blinks/honks, instead of blinking/honking after all doors are properly locked like it used to. So its not a confirmation that the car is locked now, its just a confirmation that the signal from the key was received.
Does anyone which bytes/bits might have to do with this?
Edit, some more info:
Eeprom values:
Code:
4352: 255
4355: 16
4358: 255
4361: 2
4364: 240
4370: 4
4373: 255
Coding: 00259
Adaptation:
Code:
1: 1 (Number of keys -> 1)
3: 0 (Auto lock -> OFF)
4: 0 (Auto unlock -> OFF)
5: Not availabe (Interior monitoring)
6: 1 (Unlock horn -> ON)
7: 1 (Lock horn -> ON)
8: 1 (Unlock blink -> ON)
9: 1 (Lock blink -> ON)
10: 1 (Country setting -> Rest Europe)
lijetta18t
LI NY
2019 GSW 4mo 6MT
Hi,
Code:
04361: 10 -> 2
04362: 10 -> 2
04363: 10 -> 2
Alarm activation
04355: 17 -> 16
04356: 17 -> 16
04357: 17 -> 16
Eeprom values:
Code:
4352: 255
4355: 16
4358: 255
4361: 2
4364: 240
4370: 4
4373: 255
Coding: 00259
Adaptation:
Code:
Can you also provide the values from 4367-4369?
Why did you change 4355-4357 from 16 to 17 and what did it change for you?
I have a running list of codes from various cars around the world so all of my suggested changes listed below are coming from other cars:
4352-4354 -- 255 -> 8 (This might fix your sunroof issue)
4364-4366 -- 240 -> 60 (for no audio feedback) OR 252 (for audio feedback)
4367-4369 -- Unknown but usually 255. Please provide before values before changing.
Let me know what you find. I have a list of what I know or believe each config bit is but some items I still don't know the exact setting it configures but these values are based off of other RoW Golfs.
321thijs123
The Netherlands
Thanks for your reply!
Forgot to post 4367-4369, but they are already 255 for me.
Changing 4355-4357 from 17 to 16 enabled the alarm for me, although I do not have the hood contact switch wired. But unlocking the rear lid through the lock cylinder does set off the alarm, so it is working.
I'm on vacation right now and dont have my obd cable with me, I will try the other values next week.
About value 4352-4354, is it known what this value does? I'm affraid of changing whatever value affects ignition through CAN vs wire and that locking me out of my ccm, because I dont have the CAN ignition signal.
bingo mk4
greece
golf mk4
Not sure if this helps you, but I found this in a thread a while ago and found it useful to understanding some bits.
anyone have this 'table' for 1j0 959 799 ah ccm for golf mk4 3doors??i'm looking for stock values of this ccm.
lijetta18t
LI NY
2019 GSW 4mo 6MT
Here is a re-post of my spreadsheet with known and unknown (but thoughts) of all of the values in the MK4 CCMs from the 1J0 to 1C0 modules. This includes some default values from stock and modified cars.
Link to DropBox Excel File
Remember, anything with an asterisk (*) is unknown but it includes my educated guess of what it controls/performs. I am looking to see if anyone can confirm what these bits do to let me know so I can update the sheet. You can also send me the default values for any stock cars. Just make sure you include the CCM part, Model, Year, Options (sunroof, door count, alarm system, etc).
Nuje
Fantastic! Thanks for posting that. I don't recall seeing the breakdown like that for the 1J0 CCMs before. 👍
bingo mk4
greece
golf mk4
i did the roll up/down windows with key fob in my 1j0 959 799 ah ccm
Memory Address old value new value
04295*** 138/ 64
04283 138 / 64
04289 138 / 2
08628 242 / 246
12724 250 / 254
but i lost the function roll up/down windows with key.when i lock the car with key and keep for 3-4 seconds the key in lock position or unlock.
lijetta18t
LI NY
2019 GSW 4mo 6MT
04295*** 138/ 64
04283 138 / 64
04289 138 / 2
08628 242 / 246
12724 250 / 254
Try:
04283 = 128
04289 = 128
04295 = 128
If this does not work or causes other issues, change the 128s to 2s. Let know if this works.
bingo mk4
greece
golf mk4
Try:
04283 = 128
04289 = 128
04295 = 128
thank you lijetta18t.i didn't change anything..i make a mistake.i change the 08628 to244 and 12724 to 252.i read somewhere that is more safety with this option.if i need to enable the key up/down i must change the 08628 to 246 and the 12724 to 254.instead of changing the existing by 4,if you change it by 2 it disables the key roll up/down..
Matt-98AHU
Gresham, OR
2001 Golf TDI, 2005 Passat wagon, 2004 Touareg V10.
04295*** 138/ 64
04283 138 / 64
04289 138 / 2
08628 242 / 246
12724 250 / 254
Shouldn't 04283, 04289 and 04295 be the same value? Why would 04289 be set to 2 with the others at 64?
lijetta18t
LI NY
2019 GSW 4mo 6MT
Correct! All 3 memory addresses should match whenever one is changed. Also, not sure why 2 or 64 would be good options as changing from 138 to 64 disables bit 7, 3, and 1 and enables bit 6 which makes more changes than I would expect. 2 is the same thing as it disables bits 7 and 3. I would think if you have 138 by default, 128 or 130 would be a better option. The former allows the hatch keyhole to allow comfort windows and the latter blocks them.
lijetta18t
LI NY
2019 GSW 4mo 6MT
Are you absolutely sure the list you provided earlier shows your valid stock coding?
bingo mk4
greece
golf mk4
you are right. I messed up at some point.maybe the 04289 addres have wrong old value..I asked for stock values but no one have them.
but also with these old values the windows working good.so i put the new values and the windows rolling up/down works great..
Matt-98AHU
Gresham, OR
Was messing with a 2001 or so Jetta with crank windows, knowing I previously could not write to the central LOCK module (not convenience, address 35, not 46) and went ahead, pulled some of what's on the eeprom.
I did attempt to write one address at a time manually to see what would happen, and just like VDS Pro, it will not allow me to write. Unsure on if there's a way to find if it needs a special login code first to allow being written to or what the case is.
Code:
Offset(h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00000000  30 00 D4 00 4F FF BB 00 00 A5 00 00 30 C0 00 0C  0.Ô.Oÿ»..¥..0À..
00000010  C0 03 C7 20 06 BE 63 37 B6 C3 B6 92 FF FF 82 F4  À.Ç .¾c7¶Ã¶’ÿÿ‚ô
00000020  7F FF 0C E0 FF FF 00 11 00 FF FF FF FF FF FF FF  .ÿ.àÿÿ...ÿÿÿÿÿÿÿ
00000030  FF FF FF FF FF 00 FF 00 FF 00 FF 00 D0 00 FF FF  ÿÿÿÿÿ.ÿ.ÿ.ÿ.Ð.ÿÿ
00000040  00 FF 00 FF 00 00 00 00 00 00 00 00 00 00 00 00  .ÿ.ÿ............
00000050  00 CA 44 00 00 D0 0A C8 25 00 00 00 01 00 00 00  .ÊD..Ð.È%.......
00000060  10 00 20 1E 00 00 02 57 4F 12 EB 96 A0 50 F4 6A  .. ....WO.ë– Pôj
00000070  90 00 00 00 00 00 00 00 00 02 01 03 82 00 00 00  ............‚...
00000080  00 00 87 00 00 08 00 00 00 28 00 00 00 1D 00 02  ..‡......(......
00000090  00 1F 00 1F 00 00 00 00 00 00 00 00 DD 42 DE 06  ............ÝBÞ.
000000A0  00 30 00 0A 09 03 01 28 00 68 00 00 85 00 00 00  .0.....(.h..…...
000000B0  32 00 00 00 00 80 08 08 02 64 10 08 41 21 40 00  2....€...d..A!@.
000000C0  00 00 00 00 88 88 FE FE 00 00 81 00 00 34 7A 44  ....ˆˆþþ.....4zD
000000D0  53 0A B4 20 00 00 00 00 00 00 00 DB 00 81 08 00  S.´ .......Û....
000000E0  1C 00 1E 00 01 00 00 88 C6 00 EA 81 46 1C 46 EC  .......ˆÆ.ê.F.Fì
000000F0  01 E3 00 F0 14 F5 01 F2 2B 25 51 59 00 00 00 00  .ã.ð.õ.ò+%QY....
00000100  00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF  ........ÿÿÿÿÿÿÿÿ
00000110  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00000120  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00000130  FF FF 1C CC 4D FF 93 9B 1D FE FE FF FF FF FF FF  ÿÿ.ÌMÿ“›.þþÿÿÿÿÿ
00000140  00 00 DE 30 4A FF FF FF 30 30 30 31 20 00 20 00  ..Þ0Jÿÿÿ0001 . .
00000150  5A FF FF E4 39 2F D0 00 CD AC 4D 44 EF 08 B8 84  Zÿÿä9/Ð.ͬMDï.¸„
00000160  AE 32 B7 F4 AE 7E DA E1 61 71 DF 4F 51 45 A2 03  ®2·ô®~ÚáaqßOQE¢.
00000170  97 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  —ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00000180  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00000190  20 00 00 42 50 20 20 FF FF FF E1 FF FF FF FF FF   ..BP  ÿÿÿáÿÿÿÿÿ
000001A0  1C CC 4D FF CA CC 4D FF FF FF FF FF FF FF FF FF  .ÌMÿÊÌMÿÿÿÿÿÿÿÿÿ
000001B0  A5 A5 A5 A5 A7 0D 0C 10 7A 44 5B 0A B4 FF 7A 44  ¥¥¥¥§...zD[.´ÿzD
000001C0  5B 0A B4 FF 7A 44 5B 0A B4 FF 9D C6 02 C6 27 02  [.´ÿzD[.´ÿ.Æ.Æ'.
000001D0  1C BD C6 03 2C A1 32 23 05 A6 32 C7 03 2C 0F CE  .½Æ.,¡2#.¦2Ç.,.Î
000001E0  08 09 C9 05 0D B8 02 19 B8 81 FF FF 04 10 10 10  ..É..¸..¸.ÿÿ....
000001F0  10 01 55 FF 55 55 FF 55 00 00 00 00 00 00 00 00  ..UÿUUÿU........
00000200  00 00 00 00 00 00 FD A6 32 4A 26 FD A6 80 F7 01  ......ý¦2J&ý¦€÷.
00000210  00 00 A6 20 4A 26 FD 76 24 F5 01 00 E3 F6 5C A3  ..¦ J&ýv$õ..ãö\£
00000220  54 26 E1 AE 81 BF 53 5C 26 FD BD 50 99 10 04 11  T&á®.¿S\&ý½P™...
00000230  00 AE 20 5A 26 FD 46 24 F6 98 10 00 26 F3 20 C0  .® Z&ýF$ö˜..&ó À
00000240  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000250  4F 54 86 D0 00 CD 7E DA E1 FF FF FF FF FF FF C2  OT†Ð.Í~ÚáÿÿÿÿÿÿÂ
00000260  5A 2E 1D 08 44 52 19 9C 2D 0C 00 00 00 00 00 00  Z...DR.œ-.......
00000270  00 00 00 00 2B 00 04 00 00 00 00 00 00 00 00 00  ....+...........
00000280  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1A  ................
00000290  5A 38 B0 00 00 00 00 00 00 00 DC 37 A1 01 00 00  Z8°.......Ü7¡...
000002A0  00 00 00 00 02 02 1B 04 00 FF E5 01 00 00 00 00  .........ÿå.....
000002B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000002C0  DB 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  Û...............
000002D0  00 00 00 00 00 00 A7 00 00 00 00 00 00 00 00 00  ......§.........
000002E0  AF 00 00 00 00 00 03 1A 00 3B 64 31 10 00 00 00  ¯........;d1....
000002F0  08 00 00 00 00 00 EC 00 0B 06 02 06 04 19 0C 02  ......ì.........
00000300  00 03 DE 03 03 00 00 00 00 00 00 0F 0B EF 0B EF  ..Þ..........ï.ï
00000310  0B EF 0B EF 0B EF 0B EF 0B EF 88 25 00 6B 00 FE  .ï.ï.ï.ï.ïˆ%.k.þ
00000320  68 00 15 15 15 00 00 00 00 00 00 00 00 00 00 00  h...............
00000330  00 00 00 00 00 00 00 00 00 00 00 00 00 00 6E 6E  ..............nn
00000340  6E 6E 00 00 00 00 19 19 16 0A 14 23 07 04 B4 04  nn.........#..´.
00000350  1C 0E 17 39 A5 B5 79 87 87 C8 C8 79 29 06 16 28  ...9¥µy‡‡ÈÈy)..(
00000360  4B 07 64 3C 14 65 01 01 9D C6 02 C6 27 02 1C BD  K.d<.e...Æ.Æ'..½
00000370  C6 03 2C A1 32 23 05 A6 32 C7 03 2C 0F CE 08 09  Æ.,¡2#.¦2Ç.,.Î..
00000380  C9 05 0D B8 02 19 B8 81 FF FF 96 13 84 25 75 05  É..¸..¸.ÿÿ–.„%u.
00000390  60 43 A5 11 00 6E 8B 08 AC 8B 07 F6 1E 1A 76 1F  `C¥..n‹.¬‹.ö..v.
000003A0  9F 31 63 C4 42 BC 40 C0 13 9B A0 49 97 D8 29 10  Ÿ1cÄB¼@À.› I—Ø).
000003B0  A6 C0 B7 0D 3F 0E 14 0F AE 50 0B 10 FD B6 11 F7  ¦À·.?...®P..ý¶.÷
000003C0  3A 50 27 38 5C 26 F3 AE 50 3F 16 A6 03 0A 10 09  :P'8\&ó®P?.¦....
000003D0  3A 16 26 F9 4A 26 F6 20 23 B6 11 D7 02 00 5C 26  :.&ùJ&ö #¶.×..\&
000003E0  E8 5F 3F 16 A6 03 0A 10 09 3A 16 26 F9 4A 26 F6  è_?.¦....:.&ùJ&ö
000003F0  20 0A B6 11 D7 03 00 5C A3 B0 26 E6 BC 51 00 00   .¶.×..\£°&æ¼Q..
00000400  AE 28 CD 2A E8 A1 FB 25 1B AE 29 CD 2A E8 A1 83  ®(Í*è¡û%.®)Í*衃
00000410  22 12 AE 29 CD 2A E8 A1 7D 25 09 AE 2A CD 2A E8  ".®)Í*è¡}%.®*Í*è
00000420  A1 04 23 03 A6 FF 81 4F 81 0E C4 0D 07 C4 0A 03  ¡.#.¦ÿ.O..Ä..Ä..
00000430  C2 07 09 C8 04 10 54 20 02 11 54 CD 04 D3 B7 53  Â..È..T ..TÍ.Ó·S
00000440  CD 04 F5 BA 53 B7 53 CD 04 5D CD 04 7D AD B1 BA  Í.õºS·SÍ.]Í.}.±º
00000450  53 B7 53 3D 53 27 03 1E D9 81 1F D9 81 AE 56 A6  S·S=S'..Ù..Ù.®V¦
00000460  AA 9B F7 F6 AB 56 27 02 B7 53 A6 55 F7 F6 AB AB  ª›÷ö«V'.·S¦U÷ö««
00000470  27 03 B7 53 4F F7 9A 5C A3 E4 26 E3 81 A6 D7 B7  '.·SO÷š\£ä&ã.¦×·
00000480  56 A6 02 B7 57 4F B7 58 A6 81 B7 59 AE 6A A6 AA  V¦.·WO·X¦.·Y®j¦ª
00000490  9B BD 56 A6 D6 B7 56 BD 56 AB 56 27 02 B7 53 A6  ›½V¦Ö·V½V«V'.·S¦
000004A0  D7 B7 56 A6 55 BD 56 A6 D6 B7 56 BD 56 AB AB 27  ×·V¦U½V¦Ö·V½V««'
000004B0  02 B7 53 A6 D7 B7 56 4F BD 56 9A 5C 26 02 3C 57  .·S¦×·VO½Vš\&.<W
000004C0  A3 8A 26 CA B6 57 A1 03 26 C4 3F 56 3F 57 3F 58  £Š&ʶW¡.&Ä?V?W?X
000004D0  3F 59 81 AE 50 F6 B7 56 9B A6 AA F7 F6 AB 56 26  ?Y.®Pö·V›¦ª÷ö«V&
000004E0  12 A6 55 F7 F6 AB AB 26 0A B6 56 F7 9A 5C A3 56  .¦U÷ö««&.¶V÷š\£V
000004F0  26 E3 4F 9A 81 AE 50 D6 02 00 B7 56 9B A6 AA D7  &ãOš.®PÖ..·V›¦ª×
00000500  02 00 D6 02 00 AB 56 26 18 A6 55 D7 02 00 D6 02  ..Ö..«V&.¦U×..Ö.
00000510  00 AB AB 9A 26 0B B6 56 D7 02 00 5C A3 5F 26 D7  .««š&.¶V×..\£_&×
00000520  4F 9A 81 9C CD 5D 5A CC 1B A7 C6 02 77 A4 3F 26  Oš.œÍ]ZÌ.§Æ.w¤?&
00000530  1D C6 02 77 A4 C0 A1 C0 26 06 A6 14 C7 02 77 81  .Æ.w¤À¡À&.¦.Ç.w.
00000540  C6 02 77 A4 C0 A1 40 26 0D 4F C7 02 77 81 C6 02  Æ.w¤À¡@&.OÇ.w.Æ.
00000550  77 A0 01 C7 02 77 81 C6 02 75 26 02 1F 65 81 B6  w .Ç.w.Æ.u&..e.¶
00000560  6D B1 52 26 0E B6 6E B1 51 26 08 B6 6F B1 50 26  m±R&.¶n±Q&.¶o±P&
00000570  02 4F 81 A6 01 81 BF E5 3F 59 3F E4 B6 E5 5F BF  .O.¦..¿å?Y?ä¶å_¿
00000580  E9 B7 EA B6 E4 BB EA B7 57 4F B9 E9 B7 56 B6 57  é·ê¶ä»ê·WO¹é·V¶W
00000590  AB 10 B7 EA B6 56 A9 01 B7 E9 97 B6 EA CD 5D 46  «.·ê¶V©.·é—¶êÍ]F
000005A0  A1 5A 26 3A 3F 56 B6 56 BB E5 BB 59 B7 58 97 D6  ¡Z&:?V¶V»å»Y·X—Ö
000005B0  01 00 B7 58 BE 56 EE 69 B3 58 26 22 B6 56 A1 03  ..·X¾Vîi³X&"¶V¡.
000005C0  26 14 B6 59 BB E5 B7 58 97 DE 01 00 CF 02 78 B6  &.¶Y»å·X—Þ..Ï.x¶
000005D0  E4 C7 02 87 4F 81 3C 56 B6 56 A1 03 23 C8 A6 04  äÇ.‡O.<V¶V¡.#Ȧ.
000005E0  BB 59 B7 59 3C E4 A1 10 23 92 A6 01 81 B6 6F C7  »Y·Y<ä¡.#’¦..¶oÇ
000005F0  02 6A B6 6E C7 02 6B B6 6D C7 02 6C B6 50 C7 02  .j¶nÇ.k¶mÇ.l¶PÇ.
00000600  6D B6 51 C7 02 6E B6 52 C7 02 6F 81 03 61 0D 3F  m¶QÇ.n¶RÇ.o..a.?
00000610  5B 3F 5A AD D8 13 61 15 61 A6 02 81 05 61 27 B6  [?Z.Ø.a.a¦...a'¶
00000620  6F C1 02 6A 26 0E B6 6E C1 02 6B 26 07 B6 6D C1  oÁ.j&.¶nÁ.k&.¶mÁ
00000630  02 6C 27 0B 06 61 04 16 61 20 06 3F 5A AD AE 17  .l'..a..a .?Z.®.
00000640  61 15 61 A6 02 81 3C 5A C6 02 6D A4 80 27 08 A6  a.a¦..<ZÆ.m¤€'.¦
00000650  43 C8 02 6F C7 02 6F C6 02 6F 48 C7 02 6F C6 02  CÈ.oÇ.oÆ.oHÇ.oÆ.
00000660  6E 49 C7 02 6E C6 02 6D 49 C7 02 6D 24 08 C6 02  nIÇ.nÆ.mIÇ.m$.Æ.
00000670  6F AA 01 C7 02 6F B6 5A A1 17 26 39 C6 02 6D C1  oª.Ç.o¶Z¡.&9Æ.mÁ
00000680  02 6A 26 21 C6 02 6E C1 02 6B 26 19 C6 02 6F C1  .j&!Æ.nÁ.k&.Æ.oÁ
00000690  02 6C 26 11 C6 02 6A B7 50 C6 02 6B B7 51 C6 02  .l&.Æ.j·PÆ.k·QÆ.
000006A0  6C B7 52 4F 81 B6 5B A1 C8 24 07 3C 5B 3F 5A A6  l·RO.¶[¡È$.<[?Z¦
000006B0  02 81 A6 01 81 A6 02 81 1B 61 17 5F 17 60 15 62  ..¦..¦...a._.`.b
000006C0  1F 62 19 5E 19 62 CC 06 C9 A6 F8 C4 02 80 C7 02  .b.^.bÌ.ɦøÄ.€Ç.
000006D0  80 CC 0D 19 DE BF 57 3F 56 B6 56 BB DF B7 EA 4F  €Ì..Þ¿W?V¶V»ß·êO
000006E0  B9 DE B7 E9 97 B6 EA CD 5D 46 BE 57 F7 3C 57 3C  ¹Þ·é—¶êÍ]F¾W÷<W<
000006F0  56 B6 56 A1 02 23 E2 81 DE 3F 56 3D E1 27 1B B6  V¶V¡.#â.Þ?V=á'.¶
00000700  56 BB DF B7 EA 4F B9 DE B7 E9 BE E0 F6 CD 5D 52  V»ß·êO¹Þ·é¾àöÍ]R
00000710  3C E0 3C 56 B6 56 B1 E1 25 E5 81 CE 01 39 CD 16  <à<V¶V±á%å.Î.9Í.
00000720  A9 B7 DA CE 01 3A CD 16 A9 B7 DB CE 01 3B CD 16  ©·ÚÎ.:Í.©·ÛÎ.;Í.
00000730  A9 B7 DC CE 01 3C CD 16 A9 B7 DD 3F 56 B6 56 BB  ©·ÜÎ.<Í.©·Ý?V¶V»
00000740  DA B7 58 97 D6 01 53 BE 56 D7 02 53 9F BB DB B7  Ú·X—Ö.S¾V×.SŸ»Û·
00000750  58 97 D6 01 62 BE 56 D7 02 56 9F BB DC B7 58 97  X—Ö.b¾V×.VŸ»Ü·X—
00000760  D6 01 71 BE 56 D7 02 59 9F BB DD B7 58 97 D6 01  Ö.q¾V×.YŸ»Ý·X—Ö.
00000770  80 BE 56 D7 02 5C 3C 56 B6 56 A1 03 25 BF 12 12  €¾V×.\<V¶V¡.%¿..
00000780  81 0D 65 1B C6 02 74 A1 25 25 05 1D 65 13 62 81  ..e.Æ.t¡%%..e.b.
00000790  C6 02 7B A1 08 22 05 4F C7 02 74 81 12 62 81 4F  Æ.{¡.".OÇ.t..b.O
000007A0  C7 02 74 C7 02 7B 1C 65 13 62 81 BF DD 3D DD 26  Ç.tÇ.{.e.b.¿Ý=Ý&
000007B0  44 CE 02 87 27 16 5A 27 19 5A 27 1C 5A 27 1F B6  DÎ.‡'.Z'.Z'.Z'.¶
000007C0  70 C7 02 7C 12 61 CD 06 0C A6 02 81 AE 02 A6 53  pÇ.|.aÍ..¦..®.¦S
000007D0  20 10 AE 02 A6 56 20 0A AE 02 A6 59 20 04 AE 02   .®.¦V .®.¦Y .®.
000007E0  A6 5C B7 DF BF DE AE 50 CD 06 D5 20 D2 CD 10 AC  ¦\·ß¿Þ®PÍ.Õ ÒÍ.¬
000007F0  4F 81 A6 01 81 B6 DD 4A 26 02 14 61 CD 06 0C 97  O.¦..¶ÝJ&..aÍ..—
Malhao
Portugal
VW Golf MK4 Confortline
Hello,
I've found this forum searching for some help around to get a 1C0959799B CCM working on my VW Golf MK4 2201, after replace the old (1C0959799 with a single brown T23 connector). When I rescan using the VCDS It reported has not installed. I also tested with a different CCM (1C0959799F) and got the same result. I connect only the T23 brown but believe is enough at least to get the ccm connected. Can I have an issue on both CCM, a different pinout on the cabling or something different?
Thanks in advance for any help.
Cheers
