Additional CCM coding and configurations with VDS Pro
SilverGhost
Back in So Flo - St Lucie
Well, USA and EU uses different carrier frequencies for their remotes. I think if you keep it in the same generation of CCM then the rest of the control modules and the remotes should work. And make sure they are from the same market (EU).
Jason
bingo mk4
greece
golf mk4
Jason
i will change from 1J to 1C so the remote chip is not machingonly the immo chip.yes only from (EU).thanks anyway..
Faiber
Finland
2x b5(.5) Passat Variant 1.9 TDI
1C0:
04352-4:
Bit 3: RoW cars are set to 0 but NAR cars are set to 1 and I am unsure what change happens between these.
04355-7:
Bit 4: RoW cars are set to 1 but NAR cars are set to 0. I read somewhere deep in this thread that it is something to do with Enables/Disables code execution in EEPRom patch. I question this as why would US cars be different than RoW cars?
04358-60:
Bit 6: Only NAR cars have this bit set to 1. Normally, the entire memory address is 255=RoW LHD, 16=RoW RHD, and 64=NAR so I am not sure what this channel is for. I have a suspicion that it may have to do with the frequency the KeyFob runs on but no idea.
04361-3:
Bit 2: Just confirming this operation. I have heard either that is handles if the hatch can be unlocked/opened using the trunk (boot) button on the 3 button remote OR that if you use the key lock, it will also perform comfort windows up/down (just like the drivers door).
Bit 4: Someone mentioned that this set to 1 will wipe the rear hatch wiper when unlocked. Never tried it but any idea on this?
Bit 6: Set to 1 seems to have something to do with Passat B5.5 wagons but I also noticed that Golf/Jetta Wagons have this enabled as well. 0 is for almost everything else. Do B5.5 wagons and Mk4 Wagons not have a key lock on the hatch? My friend who had a mk4 TDI NAR Wagon for years said he does not remember having a key lock.
I have germany model b5.5 passat wagon and they do have key lock on the hatch. And interesting is that it is actually 3 position switch.
1. Basic position The tailgate can be opened by means of the lock handle
2. Service position In this position, the tailgate cannot be opened by the lock handle.
3. Mechanical emergency opening
Basic position activates lock handle (switch) if car is unlocked. Micro switch on key lock will prevent that if key lock is in service position.
bingo mk4
greece
golf mk4
here again..i fixed the problems with my ccm an connections with vds-proso i keep the 1j0 959 799 AH ccm ..my question is..the roll up/down window mode working only to cars with oem alarm?if i don't have alarm or i have after market alarm?it will work?thanks guys
cuppie
Detroit, MI
02 B5.5 Passat 1.8t
Shouldn't matter if you have a basic alarm (meep horn), DWA alarm (siren), or no alarm. You do, of course, need working remote keys.
Windows roll up with VDS-PRO (cardiagnostics.be)
Can also be found in the VDS-PRO resource thread, stickied to the top of this very forum:
bingo mk4
greece
golf mk4
i have change the 4283 to 64,,the 4289 to 2,,the 08628 to 246,,,the 12724 to 254.and every combination of 1j0 959 799 AH ccm but no luck
lijetta18t
LI NY
2019 GSW 4mo 6MT
Before you keep changing these numbers, do you remember the original numbers for the channels you modified, before you used the software to change them? Let me know these and I can try to assist. Post them up here.
YYYarko
Ukraine
Volkswagen Golf4 variant 1.6 AT
Hey! Please help me figure out the problem.
There is a Golf 4 Variant version of 2001.
I decided to get myself a remote control key. I bought a 1C0959799B unit with a radio channel, I ordered a 3-button key from China, but the key does not work correctly when binding. Either only the trunk opens or the central locking. So far, I have only left the central locking system. The middle button does not work. Apparently, the block encoding is incorrect. There is no interior monitoring, no bugle, no siren. T15 was not connected yet. Coded the block (there is a COM cord and EasyCCM and VDS Pro) according to this encoding: https://forums.tdiclub.com/index.ph...nfigurations-with-vds-pro.160960/post-5226970 but the middle button still doesn't work. Now the block sees only button clicks open. and closed. (1000 and 0100) when I press the middle button to open the trunk, nothing happens (0010 is not displayed). Please help me code the unit correctly so that the radio control works as if it were from the factory (a single press of the trunk button should unlock the trunk lid and hold the button down to open the lid) Thank you in advance who will respond
Nuje
Island near Vancouver
Has anyone figured out a "unlock rear hatch with doors" on a manual-windows car?
CCM is one I haven't come across before - 1C0962258P
First few KB looks like this:
Code:
3000 D400 4FFF BB00 00A5 0000 30C0 000C C003 C720 3CE6 366F 8704 87BB FFFF 4B4B 3DFF 0CE0 FFFF 0011 FFFF FFFF FFFF FFFF FFFF FFFF FF00 FF00 FF00 FF00 FF00 FFFF 00FF 00FF 0000 0000 0000 0000 0000 0000 AD0F C800 00D0 0A10 2500 1700 3900 0004 1000 201F A000 007D 8776 AC39 FFC8 0FAD 8800 0000 0000 0000 0000 0303 9500 0000 0000 8700 0010 0000 001D 0000 0019 0006 0001 0001 0000 0000 0000 0000 9542 DE06 0030 000A 0903 0128 0066 0000 8500 0000 3200 0000 0080 0808 4064 0008 4020 0000 0000 0000 8888 FCFC 0000 8100 0034 8A44 4B0A B420 0000 0400 0000 00DB 0081 0802 1807 1E00 0100 0088 C600 EA81 8AE4 DB50 5DE3 07F0 1421 2AF4 2B25 5159 0000 0000 0000 0000 0000 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFF0 FFFF FFFF FFFF 0000 DE30 36FF FFFF 3030 3031 0202 0202 5AFF FF08 DCB3 AA26 01A2 EC51 8D42 8701 D6A7 AD0F C845 0F3A AE50 A431 E568 3381 28FF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0202 0525 5020 20FF FFFF 61FF FFFF FFFF 04AC 39FF 76AC 39FF FFFF FFFF FFFF FFFF 5A5A FFFF E57F 0B40 8A44 5B0A B4FF 8A44 5B0A B4FF 8A44 5B0A B4FF 9DC6 02C6 2702 1CBD C603 2CA1 3223 05A6 32C7 032C 0FCE 0809 C905 0DB8 0219 B881 FFFF 0380 8080 4005 55FF 55FF FFFF 0000 0000 0000 0000 0000 0000 0000 FDA6 324A 26FD A680 F701 0000 A620 4A26 FD76 24F5 0100 E3F6 5CA3 5426 E1AE 81BF 535C 26FD BD50 9910 0411 00AE 205A 26FD 4624 F698 1000 26F3 20C0 0000 0000 0000 0000 0000 0000 0000 0000 C80F AD01 D6A7 AD0F C8FF FFFF FFFF FF20 8575 5293 0558 4860 289A AD0F C8AD 0FC8 0062 0300 1800 0000 7600 0000 8888 0100 0000 0000 0000 0001 0000 0000 0000 007B 5947 ED00 0000 76AC 39FF 1CB0 8976 1CB0 8976 0000 0100 0A04 00FF D205 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FE00 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 E500 0000 0000 0000 0000 9300 0000 0000 0424 008C 6400 0400 0000 0400 0000 0000 8C00 0B04 0006 0419 0C02 0003 DE03 03FC FCFC FCFC FC0F 0BEF 0BEF 0BEF 0BEF 0BEF 0BEF 0BEF 8825 006B 00FC 6600 1515 1500 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 6C6B 6B6C 0000 0000 1919 160A 1423 0704 B404 1C0E 1739 A5B5 7987 87C8 C819 1906 1628 4B07 643C 1465 0101 9DC6 02C6 2702 1CBD C603 2CA1 3223 05A6 32C7 032C 0FCE 0809 C905 0DB8 0219 B881 FFFF 4462 2CC7 8600 9555 0D00 487B 1C2F 6426 5070 FA34 9990 9AE3 A451 4252 3000 2048 4030 FE4C 499C A6C0 B70D 3F0E 140F AE50 0B10 FDB6 11F7 3A50 2738 5C26 F3AE 503F 16A6 030A 1009 3A16 26F9 4A26 F620 23B6 11D7 0200 5C26 E85F 3F16 A603 0A10 093A 1626 F94A 26F6 200A B611 D703 005C A3B0 26E6 BC51 0000 AE28 CD2A E8A1 FB25 1BAE 29CD 2AE8 A183 2212 AE29 CD2A E8A1 7D25 09AE 2ACD 2AE8 A104 2303 A6FF 814F 810E C40D 07C4 0A03 C207 09C8 0410 5420 0211 54CD 04D3 B753 CD04 F5BA 53B7 53CD 045D CD04 7DAD B1BA 53B7 533D 5327 031E D981 1FD9 81AE 56A6 AA9B F7F6 AB56 2702 B753 A655 F7F6 ABAB 2703 B753 4FF7 9A5C A3E4 26E3 81A6 D7B7 56A6 02B7 574F B758 A681 B759 AE6A A6AA 9BBD 56A6 D6B7 56BD 56AB 5627 02B7 53A6 D7B7 56A6 55BD 56A6 D6B7 56BD 56AB AB27 02B7 53A6 D7B7 564F BD56 9A5C 2602 3C57 A38A 26CA B657 A103 26C4 3F56 3F57 3F58 3F59 81AE 50F6 B756 9BA6 AAF7 F6AB 5626 12A6 55F7 F6AB AB26 0AB6 56F7 9A5C A356 26E3 4F9A 81AE 50D6 0200 B756 9BA6 AAD7 0200 D602 00AB 5626 18A6 55D7 0200 D602 00AB AB9A 260B B656 D702 005C A35F 26D7 4F9A 819C CD5D 5ACC 1BA7 C602 77A4 3F26 1DC6 0277 A4C0 A1C0 2606 A614 C702 7781 C602 77A4 C0A1 4026 0D4F C702 7781 C602 77A0 01C7 0277 81C6 0275 2602 1F65 81B6 6DB1 5226 0EB6 6EB1 5126 08B6 6FB1 5026 024F 81A6 0181 BFE5 3F59 3FE4 B6E5 5FBF E9B7 EAB6 E4BB EAB7 574F B9E9 B756 B657 AB10 B7EA B656 A901 B7E9 97B6 EACD 5D46 A15A 263A 3F56 B656 BBE5 BB59 B758 97D6 0100 B758 BE56 EE69 B358 2622 B656 A103 2614 B659 BBE5 B758 97DE 0100 CF02 78B6 E4C7 0287 4F81 3C56 B656 A103 23C8 A604 BB59 B759 3CE4 A110 2392 A601 81B6 6FC7 026A B66E C702 6BB6 6DC7 026C B650 C702 6DB6 51C7 026E B652 C702 6F81 0361 0D3F 5B3F 5AAD D813 6115 61A6 0281 0561 27B6 6FC1 026A 260E B66E C102 6B26 07B6 6DC1 026C 270B 0661 0416 6120 063F 5AAD AE17 6115 61A6 0281 3C5A C602 6DA4 8027 08A6 43C8 026F C702 6FC6 026F 48C7 026F C602 6E49 C702 6EC6 026D 49C7 026D 2408 C602 6FAA 01C7 026F B65A A117 2639 C602 6DC1 026A 2621 C602 6EC1 026B 2619 C602 6FC1 026C 2611 C602 6AB7 50C6 026B B751 C602 6CB7 524F 81B6 5BA1 C824 073C 5B3F 5AA6 0281 A601 81A6 0281 1B61 175F 1760 1562 1F62 195E 1962 CC06 C9A6 F8C4 0280 C702 80CC 0D19 DEBF 573F 56B6 56BB DFB7 EA4F B9DE B7E9 97B6 EACD 5D46 BE57 F73C 573C 56B6 56A1 0223 E281 DE3F 563D E127 1BB6 56BB DFB7 EA4F B9DE B7E9 BEE0 F6CD 5D52 3CE0 3C56 B656 B1E1 25E5 81CE 0139 CD16 A9B7 DACE 013A CD16 A9B7 DBCE 013B CD16 A9B7 DCCE 013C CD16 A9B7 DD3F 56B6 56BB DAB7 5897 D601 53BE 56D7 0253 9FBB DBB7 5897 D601 62BE 56D7 0256 9FBB DCB7 5897 D601 71BE 56D7 0259 9FBB DDB7 5897 D601 80BE 56D7 025C 3C56 B656 A103 25BF 1212 810D 651B C602 74A1 2525 051D 6513 6281 C602 7BA1 0822 054F C702 7481 1262 814F C702 74C7 027B 1C65 1362 81BF DD3D DD26 44CE 0287 2716 5A27 195A 271C 5A27 1FB6 70C7 027C 1261 CD06 0CA6 0281 AE02 A653 2010 AE02 A656 200A AE02 A659 2004 AE02 A65C B7DF BFDE AE50 CD06 D520 D2CD 10AC 4F81 A601 81B6 DD4A 2602 1461 CD06 0C97 5D27 EA5A 27EC 03B9 EC20 BEC6 0280 A407 5FB7 575D 2603 CC0C 3DA6 F8C4 0280 C702 800C 6503 CC0C 5FA6 0681 015F 12A6 01CB 0280 C702 800F 6010 1F60 075F 2920 E20D 6503 A606 81A6 0381 1161 0760 D4A6 1EBA 63B7 6311 5FA6 40CA 0277 C702 77CD 06B8 0D65 62A6 0681 1563 C600 5CA1 3D26 481A 6401 5E02 2003 0166 0B12 5F16 5F1D 6513 62A6 0481 135F 0362 050E B502 2093 A601 CB02 80C7 0280 095E 2F0F B512 1763 CD05 5F4D 2608 1862 1963 1E64 1063 1C64 185E 5FCD 07AB CC0A 70A1 0523 041B 6418 63CD 06C9 CC08 21A6 0381 0FB5 0F0E 620E 1E62 0964 0213 63CD 10E0 2002 1964 03BB 03CC 0821 0FB5 0217 63AE A0CD 0576 4D27 AA1D 64CC 0819 0966 151F 60B6 6FC7 026A B66E C702 6BB6 6DC7 026C 3FDC 203C 0F60 19C6 005C A13D 2612 C602 78B1 6926 0B1F 60B6 70C7 027C AE01 2004 1F60 AE02 CD07 ABB7 DCC6 0277 A43F 2710 B6DC A102 270A 3DDC 2602 1862 A601 B7DC BEDC 2709 5A26 03CC 0A90 CC08 213F 56BE 56E6 69D7 0296 D602 9AD7 029E 3C56 B656 A104 25EB 145F B66D C702 50B6 6EC7 0251 B66F C702 521E 6410 6319 631D 6513 6216 5F17 621E 65A6 64C7 0275 1960 1161 1B61 4FC7 027E A680 CA02 77C7 0277 1A63 0866 4DCD 1429 4D26 39C6 027C C702 7D11 64CD 0D19 C602 7CA4 0827 0418 6514 65C6 027C A410 2704 1A65 1665 C602 7CA4 2027 0410 651C 61C6 027C A440 273C 1265 1E61 2036 0164 07CD 0D19 4FC7 027C 1064 2028 C602 8726 0F0B 660A 1E66 CD13 43A6 3CC7 0279 1B66 C602 874A 260E 0D66 091E 66CD 1343 4FC7 0279 1D66 0565 3ACD 31EE B7DB 979F B758 9FB7 59B6 91BA 90B4 59B1 5826 1CA6 79C7 02C6 1C62 3D90 2603 0F7D 0416 BF20 12C6 0087 270D 09B8 0A20 F20D 6205 A679 C702 C6CE 0287 2718 5A27 1B5A 2724 1FD8 A60F C402 86C7 0286 A601 CB02 80CC 081E 19D8 A6F0 2004 1BD8 A60F C402 85C7 0285 20E6 1DD8 A6F0 20DA 155F 1963 1F64 CD05 5F4D 2703 0962 021E 64A6 F8C4 0280 C702 805F 4FC7 0290 CF02 8F04 620F 0EB5 0C0E 6409 C602 6AB1 5027 3B20 470F 6404 4FC7 027B 0E64 2804 6225 0C63 14C6 026A C702 93C6 026B C702 94C6 026C C702 951C 63CE 0287 2729 5A27 405A 2759 5A27 7014 6216 62A6 0681 C602 6BB1 5126 07C6 026C B152 2707 A601 CB02 7B20 B61E 6420 B5A6 01CB 0285 C702 85A4 0FA1 0525 D2A6 F0C4 0285 C702 8518 D820 C6A6 10CB 0285 C702 8544 4444 44A1 0525 B6A6 0FC4 0285 C702 851A D820 AAA6 01CB 0286 C702 86A4 0FA1 0525 9CA6 F0C4 0286 C702 861C D820 90A6 10CB 0286 C702 8644 4444 44A1 0525 80A6 0FC4 0286 C702 861E D8CC 0AF5 0F60 430A 6140 1F60 0966 03CC 0C31 1161 1861 C602 7EA1 0824 0AA6 01CB 027E C702 7E19 6117 5F1E 65A6 64C7 0275 3FDD AE07 CD0C 635F 2677 4D26 741B 5ECD 0D19 CE02 7DCD 0CFC 2069 0760 0220 030B 610E 1F60 A61E BA63 B763 0961 0C4F 200E C602 E2A1 3F25 1A20 48A6 40CA 0277 C702 7719 6111 5FCD 06B8 0D65 03A6 0681 A603 8144 4444 975D 272B BFDC A307 2504 A607 B7DC A602 B7DD BEDC AD4B 5FA3 0026 14A1 0126 10C6 02E2 4444 44B7 58B6 DCB1 5822 0210 6100 6103 CC08 21CD 0D19 CC08 2197 5D26 03CC 082A 5A26 03CC 0835 5A26 03CC 0896 5A26 03CC 08F4 5A26 03CC 0B82 CC08 19A6 0281 DDBF DEB6 DDB7 DF3D DF26 11A6 3FC0 005C B7E0 A102 2306 3AE0 3AE0 2002 3FE0 3FE1 3DDE 276A B6E1 A104 2413 3DDF 2609 97D6 029E D802 9A20 2897 DE02 9E20 1A3D DF26 0FA6 06B0 E197 EE50 BFE2 BEE1 E669 200D A606 B0E1 97EE 50BF E2BE E1E6 71B8 E2B7 E208 6517 0A65 1400 6511 0265 0E3D E226 0A0A 5E07 1A5E CE02 7DAD 1F01 E202 3CE0 34E2 B6E2 26F5 3CE1 B6E1 B1DE 2596 B6E0 C103 6425 03A6 0181 4F81 9FA4 0827 0218 659F A410 2702 1A65 9FA4 2027 0210 659F A440 2702 1265 81A6 CCB4 65B7 6581 1B61 0961 1B00 6105 4FC7 0270 81C6 0270 A164 2303 1A61 81A6 01CB 0270 C702 7081 4FC7 0270 81BF 579F B756 97DE 01B0 A35A 260A CE02 87DE 01B0 A35A 2703 A601 8138 5638 56B6 56B7 57C6 0287 4848 B759 B656 AB04 979F B758 B657 B158 2425 BE57 D601 A0B7 58BE 59DE 01A0 B358 2703 A601 813C 573C 59B6 56AB 0497 9FB7 58B6 57B1 5825 DB4F 81BF 56CE 027A 270B 5A27 154F C702 7A17 5E4C 81A6 FFC7 0276 4FC7 02F5 4CC7 027A C602 76A1 0426 0CC6 02F5 2607 175E 4FC7 027A 81C6 02F5 2635 A601 CB02 76C7 0276 A104 260D C602 87AB B0B7 9DA6 5AB7 9E20 0CBB 56B7 9DCE 0276 DE02 96BF 9E10 BBA6 11C7 02F5 165E A601 C702 7A4C 81A1 5526 F317 5E4F C702 7A4C 81C6 028F A102 2605 C602 90A1 5925 0211 5E81 0BD1 03CC 10A5 CD16 08CD 16EA CD14 D8CD 0557 CD12 9BCD 12F8 CD05 2ACD 0D20 CE02 8127 5A5A 2771 5A26 03CC 0EDF 5A26 03CC 0F01 CE02 8B26 03CC 0F1B 5A26 03CC 0F57 4FC7 028B CE02 8A26 03CC 0F66 5A26 03CC 0F8D 5A26 03CC 0FB0 5A26 03CC 0FD3 5A26 03CC 1005 5A26 03CC 1037 5A26 03CC 1066 5A26 03CC 1095 1D63 4FC7 028A 8101 5F06 145E A602 2063 005E 080C 6205 0E65 0215 5E19 651B 6520 9B06 6205 0C65 0220 4907 6203 CD13 430D 6503 CD07 8101 5F84 A602 C702 81CD 080B 97A3 0327 2DA3 0427 07A3 0627 07CC 0E5E A603 201F A601 C702 81CD 0781 CC0E 5E01 5F03 CD08 0BCD 10FB 975D 2706 5A27 03CC 0E5E 4FC7 0281 CC0E 5EC6 0287 A103 2203 CC0E 70A1 FF26 03CC 0E70 05BB 03CC 0E70 C601 8FC1 0287 2603 CC0E 7014 BBC6 0287 B79E A68F B79D 10BB A611 C702 F5A6 01CB 028B CC0E 6DC6 02F5 A111 2603 CC0E 7015 BBCC 0E6C 0C63 03CC 10AB 05BB 03CC 10AB 14BB C602 93B7 9EA6 36B7 9D10 BBA6 11C7 02F5 A601 CB02 8AC7 028A 81C6 02F5 A111 2603 CC10 ABC6 0294 B79E A637 B79D 10BB A611 C702 F5A6 01CB 028A C702 8A81 C602 F5A1 1126 03CC 10AB C602 95B7 9EA6 38B7 9D10 BBA6 11C7 02F5 A601 CB02 8AC7 028A 81C6 0131 A1FF 262B C602 F5A1 1126 03CC 10AB C602 8748 48B7 5897 DE01 A0BF 9EA6 32B7 9D10 BBA6 11C7 02F5 A601 CB02[\code]
bingo mk4
greece
golf mk4
no i didn't keep the original numbers.i know thats my fault.but i put some other numbers that i found from here and the windows are working fine..but i can't get the windows roll up/down with keyfob.what do you need the original numbers?i have an other ccm same code 1j0 959 799 AH.I have not touched
ahmedj9579
tunisia
vw MK4
Hi every body.
really an interesting topic.
by the way, did someone manage to locate the bit in order to fold/unfold mirrors with FOB key?
just to come back to the story of installing TLE6208-3 and wire the mirror with the window power module.
the only way to manage folding /unfolding is through the interior switch.
i follow all the conversation and looks like there is a change to modify a bit to include the feature using a key.
"CCM is 1C0"'
really appreciate
cuppie
Detroit, MI
02 B5.5 Passat 1.8t
Hi every body.
"CCM is 1C0"'
really appreciate
As far as I know (I did research on this when the wife had her GLX wagon)... you can't. I do remember reading a thread (maybe here, maybe somewhere else) where the user wrote about installing an Audi power folding mirror 'relay' to gain that function.
VN86KEN
Romania
passat B5.5 1.9 AVF
Yes , to fold when you close car from fob key you need an Audi relay 361 installed or an module. You can find module to FB.
punkassjim
Anyone ever successfully re-coded a 4-door vehicle so it thinks it’s a 2-door? On my 1J0 CCM I’ve tried address 4280/86/92, bit 4 (“possible door count”), and it didn’t do anything.
My car is a mk3 GTI with the complete guts of a mk4 Jetta Wolfsburg, so I’m sure this is a fairly esoteric problem to solve. I don’t have the rear door controllers plugged in, so when I lock the car there’s a 1-second delay before the confirmation beep. Would love to code out that fault.
punkassjim
Does the delay go away if you plug the controllers in?
It’s been 17 years since I did the swap, but I’m pretty sure I tried that back in the day. Don’t have the door controllers anymore. Pretty sure I still would’ve had to connect the lock boxes too, and I just don’t want that much dead weight rattling around behind my trim panels.
lijetta18t
LI NY
2019 GSW 4mo 6MT
Maybe try Bit 4 and Bit 0 on the three memory addresses? Could be a mix between them. I’ll take a look. If possible, can you get the full memory dump if 3 cars (all with 1J0 CCMs): 3 door golf, 5 door golf, and jetta. I have long not had access to any of these however, if I can grab a few CCMs from the junkyard, I will.
WPhH
Portugal
2000 Passat B5 Variant 1.9 TDI
Hello everybody, I cannot get my windows to work via keyfob. The car is a 2000 model Passat B5 Variant with central locking and alarm system, but it only has electric windows on the front doors.
The CCM is a 1J0 959 799 S.
Colour-code of CCM is 3B, soft coding is 00257.
Door control modules are 1J1 959 801D and 1J1 959 802E.
I have been using KW1281test. Here are the old and new values I have been trying with no success:
04283 8 2
04289 8 2
08628 242 246
12724 250 254
Is it perhaps not possible to get this working when only the front windows are electric? Or are there perhaps any other values that I should try? I cannot find any answers despite searching the web for many hours. Thank you all for helping!
graeme86
Brisbane, Australia
Not yet - fuel is too cheap! - 3.2 VR6 R32
You have to turn off the bit rather than just use "2" for example (which some others may have quoted for their car that worked)..eg the bit for the windows is xxxx1xxx = "deactivated" at 04283, 04289 and also 04295 by the way!.
To "activate" the feature you have to put 0 in that bit...so if your value is 8 = 00001000 then new value is 0 = 00000000
WPhH
Portugal
Hi Graeme86, Thanks for your swift reply! I just tried as per your post writing O to 04283, 04289 and also 04295. However, it does not work.
lijetta18t
LI NY
2019 GSW 4mo 6MT
I looked over your info a bit more and it looks like you forgot the rear doors as well. Can you read out addresses 16820 and 20916? This should work as long as your rear doors are not manual crank windows.
Also, are you positive that addresses 04283, 04289, and 04295 where set to 8 before changing anything? If this is the case, a value of 0 or 2 should help, as long as all 3 addresses are set the same. Maybe try re-writing all of these addresses again? Just so you know, value of 0 allows the keyfob to work while the car is running and 2 disables they keyfob while car is running.
One last thing, can you read out the data from these addresses? I want to add to the known cars list I have been building:
04280, 04281, 04282, 04283, 04284, 04285, 08257, 08628, 12353, 12724, 16820, 20916
WPhH
Portugal
Hi Lijetta 18T, thanks for your interest. I have been thankfully using your spreadsheet trying to get this to work. But I just can not get this to work.
My rear windows are manual and my CCM does not seem to have addresses 16820 and 20916.
Yes I am positive, the original value of 04283, 04289 and 04295 was 08.
Here are the values you ask for:
04280 FF
04281 FF
04282 FF
04283 08
04284 FC
04285 FF
08257 FF
08628 F2
12353 0B
12724 FA
16820 -
20916 -
I can send you the Eeprom dumps if they are of use for you.
lijetta18t
LI NY
2019 GSW 4mo 6MT
Thanks for that! Added to the spreadsheet. So, everything look to be set right. My question is do comfort windows work with the door key lock currently? It should but if this does not work, there might be something else at play elsewhere. Otherwise, I am not sure at this point. You have re-written all values again since the last message, right?
WPhH
Portugal
Yes they work fine with the door key lock. I re-wrote all the original values back after trying various combinations... Mine must be the first B5 were this just doesn't work.. can't find any other case like mine even after weeks of browsing, in the end everyone that tried got it working :(
lijetta18t
LI NY
2019 GSW 4mo 6MT
Very strange! Anyone else that can chime in on these early 1J0 CCMs? We must be missing something here.
Mozambiquer
Versailles Missouri
I did it on my early golf with 1j0 ccm, and the data was in different locations from my 1C0 passat one. I'll have to look back from when I did that.
Nuje
I've never had any luck with doing the window remote (or hatch) on a 1J0 CCM. :(
WPhH
Portugal
Hello Mozambiquer, can you please let me know how you managed to do it? Thank you so much in advance!
