graeme86 said:
While you're poking around in that SEAT Leon module...
You haven't found anything to activate the following:
Fold in the electric mirrors with the key fob, when locking car?
I believe some SEATs can do this standard if they have the folding moirror option. (may also require the appropriate window motor controller as well??)
Sorry, but my car does not have folding mirrors... but I designed a small circuit to do that, in another local forum in Spain where I actively parcitipate, exactly for that... let me place the link here:
http://www.vagclub.com/forum/viewtopic.php?t=16917&start=45
Some people have installed this simple circuit in superb, passat, leon and toledo models and they confirm that I works (I just could test the theorical part when I designed the circuit :-( ). Hope it helps!
I agree with you that the hacking way would be nicest way. And I trust that within this (tdiclub.com) I have found the BEST collaboration ever, so I guess that if we join our efforts, we can reverse-engineer the CCM to know it all. From my side, this are my conclussions until now:
This is what I found-out:
Addr. 0 1 2 3 4 5 6 7 8 9
04100 255 255 255 255 255 255 255 255 255 255 --> faults memory. Each position is a different fault code
04110 255 255 255 255 255 255 255 255 255 255
04120 255 40 40 40 40 255 40 255 255 255
04130 255 255 255 255 255 255 255 255 255 255
04140 255 255 255 255 255 255 255 255 255 255
04150 255 255 255 255 255 255 255 255 247 223 --> 4150 incl. end of faults mem.
04160 0 0 222 57 86 255 255 255 48 48
04170 48 52 2 4 2 4 90 255 255 0 --> coding (2, 4, 2, 4); key rotation code (starts at 04179)
04180 77 23 0 77 24 0 77 20 0 77
04190 21 0 77 22 255 255 255 255 255 255
04200 255 255 255 255 255 255 255 255 255 255
04210 255 255 255 255 255 255 255 255 255 255
04220 255 255 255 255 255 255 255 255 255 255
04230 255 255 255 255 255 255 255 255 255 255 --> end keys rotation codes (4 keys)
04240 2 4 0 222 70 32 32 255 255 255 --> coding (2,4); workshop_code_00222 (2,4,0,222,70,32,32,255,255,255)
04250 255 255 255 255 255 255 7 179 46 76 --> key code start: 4256
04260 255 255 255 255 255 255 255 255 255 255 --> key codes
04270 255 255 90 255 255 255 254 255 255 255 --> key codes
04280 1 255 255 255 255 255 255 255 255 255
04290 255 48 49 48 55 48 52 255 255 255
04300 255 255 255 255 255 255 255 255 255 255
04310 255 255 255 255 255 255 255 255 255 255
04320 255 255 255 255 255 255 255 255 255 255
04330 255 255 255 255 255 255 255 255 255 255
04340 255 255 255 255 255 68 94 182 21 161 --> configuration registers
04350 162 161 68 68 68 17 17 17 255 255 --> configuration registers
04360 255 10 10 10 48 48 48 255 255 255 --> configuration registers
04370 4 4 4 255 255 255 255 255 255 255 --> configuration registers
04380 255 255 255 255 255 255 255 255 255 255 --> maybe configuration reg.
04390 255 255 255 255 255 255 255 255 255 255
04400 255 255 255 255 255 255 255 255 255 255
04410 255 255 255 255 255 255 255 255 255 255
04420 255 255 255 255 255 255 255 255 255 255
04430 255 255 255 255 255 255 255 255 255 255
04440 255 255 255 255 255 255 255 255 255 255
04450 255 255 255 255 255 255 255 255 255 255
04460 255 255 255 255 255 255 255 255 255 255
04470 255 255 255 255 255 255 255 255 255 255
04480 255 255 255 255 255 255 255 255 255 255
04490 255 255 255 51 51 51 255 255 255 255
04500 255 255 129 129 129 255 255 255 255 255
04510 255 255 255 255 255 255 255 255 255 255
04520 255 255 255 255 255 255 255 255 255 255
04530 255 255 255 255 255 255 255 255 255 255
04540 255 255 255 255 255 255 255 255 255 255
04550 255 255 255 255 255 255 255 255 255 255
04560 255 255 255 255 255 255 255 255 255 255
04570 255 255 255 255 255 255 255 255 255 255
04580 255 255 255 255 255 255 255 255 255 255
04590 255 255 255 255 255 255 255 255 255 255
About the configuration registers:
Feature Address Bit
undefined 04349,50,51: xxxx xxx-
undefined 04349,50,51: xxxx xx-x
undefined 04349,50,51: xxxx x-xx
undefined 04349,50,51: xxxx -xxx
undefined 04349,50,51: xxx- xxxx
undefined 04349,50,51: xx-x xxxx
undefined 04349,50,51: x-xx xxxx
undefined 04349,50,51: -xxx xxxx
undefined 04352,53,54: xxxx xxx-
undefined 04352,53,54: xxxx xx-x
autounlock (on=1, off=0) 04352,53,54: xxxx x-xx
undefined 04352,53,54: xxxx -xxx
undefined 04352,53,54: xxx- xxxx
undefined 04352,53,54: xx-x xxxx
autolock (on=1, off=0) 04352,53,54: x-xx xxxx
undefined 04352,53,54: -xxx xxxx
F120 (on=0, off=1) 04355,56,57: xxxx xxx-
undefined 04355,56,57: xxxx xx-x
Int.Mon. Ch.5 (on=1, off=0) 04355,56,57: xxxx 1-xx
Int.Monitoring(on=1, off=0) 04355,56,57: xxxx -xxx
undefined 04355,56,57: xxx- xxxx
undefined 04355,56,57: xx-x xxxx
heated mirrors(yes=0, no=1) 04355,56,57: x-xx xxxx
undefined 04355,56,57: -xxx xxxx
undefined 04358,59,60: xxxx xxx-
undefined 04358,59,60: xxxx xx-x
undefined 04358,59,60: xxxx x-xx
undefined 04358,59,60: xxxx -xxx
undefined 04358,59,60: xxx- xxxx
undefined 04358,59,60: xx-x xxxx
undefined 04358,59,60: x-xx xxxx
undefined 04358,59,60: -xxx xxxx
undefined 04361,62,63: xxxx xxx-
undefined 04361,62,63: xxxx xx-x
undefined 04361,62,63: xxxx x-xx
autowindows (on=0, off=1) 04361,62,63: xxxx -xxx
undefined 04361,62,63: xxx- xxxx
undefined 04361,62,63: xx-x xxxx
undefined 04361,62,63: x-xx xxxx
undefined 04361,62,63: -xxx xxxx
undefined 04364,65,66: xxxx xxx-
undefined 04364,65,66: xxxx xx-x
undefined 04364,65,66: xxxx x-xx
undefined 04364,65,66: xxxx -xxx
unlockBlink (on=1, off=0) 04364,65,66: xxx- xxxx
lockBlink (on=1, off=0) 04364,65,66: xx-x xxxx
unlockHorn (on=1, off=0) 04364,65,66: x-xx xxxx
lockHorn (on=1, off=0) 04364,65,66: -xxx xxxx
undefined 04367,68,69: xxxx xxx-
undefined 04367,68,69: xxxx xx-x
undefined 04367,68,69: xxxx x-xx
undefined 04367,68,69: xxxx -xxx
undefined 04367,68,69: xxx- xxxx
undefined 04367,68,69: xx-x xxxx
undefined 04367,68,69: x-xx xxxx
undefined 04367,68,69: -xxx xxxx
undefined 04370,71,72: xxxx xxx-
undefined 04370,71,72: xxxx xx-x
undefined 04370,71,72: xxxx x-xx
undefined 04370,71,72: xxxx -xxx
undefined 04370,71,72: xxx- xxxx
undefined 04370,71,72: xx-x xxxx
undefined 04370,71,72: x-xx xxxx
undefined 04370,71,72: -xxx xxxx
undefined 04373,74,75: xxxx xxx-
undefined 04373,74,75: xxxx xx-x
undefined 04373,74,75: xxxx x-xx
undefined 04373,74,75: xxxx -xxx
undefined 04373,74,75: xxx- xxxx
undefined 04373,74,75: xx-x xxxx
undefined 04373,74,75: x-xx xxxx
undefined 04373,74,75: -xxx xxxx
And this is where I am right now :-( Still lot of work to do...
