300D
Last summer I just about completely rebuilt my AC. New compressor, new condenser, new Fan Control Module, new drier, new expansion valve. Seemingly all good parts from AutoHausAZ. Compressor is a Nissens. Early this summer I discovered it not working again. Thought that maybe it was a leak at the drier. I really struggled getting good access at that point to get a good feeling tight connection. I pulled out my gauges and discovered that the pressures are good. Did the fan test, and both fans are coming on. Checked the pressure switch duty cycle and it was within spec. Checked all the fuses and they are all good. Pulled apart the fuse connector on top of the battery and there is no corrosion under there. Tested the power at the compressor plug. The AC troubleshooting guide says that there should be 9-9.5 volts at the connector, but I got something a wee bit different. First I tested unplugged with car running and AC on and I got 10.5V. Then I tested it again with the car running, but with it plugged in and I got about 11.6V with the AC system switched off, and 12V with the system switched on. Throughout all this, compressor clutch is not engaging. I am about to give up and bring it to a respected VW mechanic, but figured I would check in here first. Although I have not tested resistance yet on the compressor plug, my feeling is the Nissens compressor's clutch is the culprit.
What do people think? Do I need to go through the rest of the troubleshoot? Or have I narrowed it down to a faulty compressor clutch? It just kills me to think that I have all new bits in there and maybe one of them has already failed.
Oddly enough, the car's idle does just barely drop when turning on the AC. I am chalking this up to the fans coming on and adding load to the alternator.
