Fans run fine and compressor clutch engages fine when ac button is pressed. Just replaced txv valve which was original and had alot of bb looking ferrous material in it from a previous failed compressor I assume. Most threads here show 30 low 175 psi is reasonable at 75 psi ambient so no shortage of info there. I don't think it's an electrical problem and that thread is 69 pages long. Cools to about 62 in the shade at 75 degree ambient. Pulled a vacuum for about an hour and fed it 28 ounces of r134.Check your radiator/condenser fan operation NOW
Mk IV Manual AC electrical & cooling fan troubleshooting and repair Now is the time of the year to check that your pair of electric fans that provide cooling for both the radiator and air conditioner condensor are functioning. Do not needlessly age your Air Conditioning compressor by running it...forums.tdiclub.com
Start there. Post 1 has links to step by step troubleshooting guides, check for electrical issues first.
I've actually never checked pressures in a MK4 AC system, always found an electrical issue before getting that far.
No, I did not flush the system. I did not change the drier. I was a bad boy I know. I have a condenser with drier ready to put on but it looks like a pain in the butt to install.Did you flush the system to get all the junk out from the failed compressor? Replace the receiver dryer? Also possible your blend doors are doing the famous foam fall off.
I have been holding off checking this stuff cause I was scared of the enormity of the task. Is there any video on checking this. I am having a hard time visualizing this.Just to add to dieseldonato statement check and see if you can move the blend door .
See if the pivot on the bottom , aft of the air bag module has dropped down about 1/8 of an inch. You need to remove the panel next to the go pedal and take a look.
Why? It doesn’t take much to fix them. Just because it new doesn’t mean that won’t break too.My AC hasn't worked in a few years. Fans won't come on.
MkIV's are going on 20 years old now, just let them die gracefully.
If you want AC, buy a new car.
Oh heck no!!!! I wish I had it as easy as you! My 21 year old sedan blows ice cold with me at the helm of both AC systems even with foam spitting in my eyes!My AC hasn't worked in a few years. Fans won't come on.
Dear sir,MkIV's are going on 20 years old now, just let them die gracefully.
