AZyeaha
AC hi on low pressure side no cooling-fixed
I have a 2000 beetle tdi. The ac suddenly was blowing warm. Checked with gauges low side running at 60 -70 hi side normal 200-225. switched out expansion valve got same readings. Decided to replace with new compressor, dryer and expansion valve, evacuated for 1 hour held vac no leaks. Charged system was getting close to normal readings cool air, next day back to hi pressure on low side warm air?? I had blown out all the lines, drained the new compressor of oil, distributed the required amount of oil between compressor dryer and evaporator. Turned the compressor by hand many turns before charging, also after first can of 134 turned by hand before startup, then charged. I have now noticed the fans do not come on with ac. Compressor engages still hi pressure on low. Jumped the fans to stay on while running with compressor engaged still same readings. I will have to replace the fans, power is getting to them as volt meter tested, direct current to fans only run on hi low terminal direct current no run. I'm I missing something here or could my internal Refridgerant Control Valve be bad in by new compressor?? Meanwhile I will work on the fan issue and double check the condenser is clean and not blocked by debris. AC reading were made in Arizona heat around 100-105 deg. at several times. I have done many compressor and recharge/repairs projects on other model cars, no problems Thanks for any insight to this issue
