jettajim
Car: '00 Jetta TDI, auto with 177k
Symptoms: 'clattering, vibration type sound' when AC on. When the ac is turned off, the noise goes away sometime not instantly.
Here's what I did:
- removed belt and turned the alt pulley in both directions--it locked in one direction as it should
- Replaced ac coil and ac clutch but this didn't change anything
- Replaced ac pulley bearings and this worked for about a day now the sound is back
Before I did anything, with the engine running & my wife in the car, I was under the car and watched the ac compressor. When the 'noise' happened, the ac clutch stopped. This is why I thought it was the clutch.
Since the noise is still there after doing this stuff to the AC and checking the alt pulley, I think I have a bad compressor. I changed the compressor once before at ~90k.
Is this the only way the verify that the alt pulley is good or bad?
I want to here your thoughts before I do anything else.
I appreciate it!
Thanks,
Jim
Here's what I did:
I appreciate it!
Thanks,
Jim
