ss010949
convert ABS to non ABS breaks on MK4 jetta wagon
Pull one of your speed sensors and it disables the abs. Plug back in when you want for abs to work. Pretty great system lolconvert ABS to non ABS breaks on MK4 jetta wagon
My car passed NYSI with the light on.i wouldn't mind the abs light staying on all the time , but they will not pass it for inspection in NY . no beeps or anything just the abs light on all the time , but brakes work fine otherwise
Interesting. I know the B5 ABS modules had a similar issue but it was with solder joints on hair-thin wires. I sent it out to be repaired, and you could still drive the car. I guess with A4 chassis cars you can’t do that. But if I could solder it myself (I’ve done some guitar pickup soldering) then vehicle down-time is greatly reduced. I did find a place online that will fix my module (‘03 but no ASR) for like $100. But it’s through the mail of course so the better part of a week.There’s a problem with the ABS modules….. more so with the Two plug version , I believe it’s the MK40 .
I think the 02 and 03 use the big connector , Mk 60.
Im assuming that the wiring is the same just plugged into the connector a different way.
The problems I had with the abs I believe was the same code you had. The problem is the solder joints are cracking that power the pump itself.
There was a write up on vortex on how to cut the top of the controller , verify a cracked solder joint and resolder all the heavy wired joints.
All of my cars are Mk 40’s except for the one 03 I have ( mk60 ). I’ve bought a couple off eBay that are ASR , as I’ve installed them on all our cars ( traction control , cheap position traction ) but before I did I took each one apart and found all cracked , resoldered the joints and all are good now.
If you still have your old one cut the back off your controller and inspect the solder joints to the motor for cracked solder…might be an easy fix.
Also you can look on EBay for an Mk 60 , ABS with ASR , it makes a difference in the winter and wet roads when pulling out onto a street….no more one tire spinning , you do have to step on the go pedal more ( the abs with asr uses the abs braking system to stop spinning the slipping wheel and force the other wheel to turn there’s a light already on the cluster that will flash when engaged and you will hear it to ).
Normally ASR is issued to vw’s that are gas powered not diesels. But for me I live in the hills and helps tremendously in the snow. Just my .02.
Ok I will look into sourcing an ABS module with the ASR.I’d look for one with ASR , cut the controller top off ( carefully with a hack saw blade in your hand ) inspect , repair it and install it…….I don’t think you’d be sorry and down time is only a few hours. You will need VCDS to bleed the ABS system.
I know the neck of woods your in as I’m only 2 hours south of you.
My Beetle doesn't beep - just the solid ABS light on the dash.I just drive with the solid ABS and blinking BRAKE lights. The beeps I don’t even hear any more.
Maybe for a new pump , but there are plenty of used salvageable units out there .It's hard to justify $1000 - $2000 repair on a 22 year old car. (needs replacement ABS pump)
I think I paid $130.00 off eBay for the last one with ASR.
I was quoted the $1000 for a USED pump from the junkyard.
That's crazyI was quoted the $1000 for a USED pump from the junkyard.
