middle40
Hi all,
....Apologies if this is in wrong section. Can never find a Touran specific one in vw/tdi forums
Have a touran TDI 2013.
ABS light used to come on sporadically. New battery seemed to cure the fault. Then slowly came & went again. Now on permanent.
ABS Lights on dash on startup, extra warning light comes on when driving over 10mph. Have cleared codes they come back. I've read some threads about checking fuses, connections and cleaning grounds under battery.
All good pointers but a little vague - what fuses to check / replace? All looks good in there.
Someone mentioned connection under steering column and I'm sure one of the faults came up on scan when checking steering angle sensor but i might be imagining that bit
I'm assuming dodgy connection somewhere but not sure how to investigate.
Any help appreciated
Cheers
M.
Cheers
M.
