Trail Mutant
Malfunction Indicator Light stay on. Has this been discussed before? Fuses are okay. Not crazy about just replacing the Hydraulic Pump.
2004 Jetta TDI 280,000 miles.
Do you have any more thoughts on my first response?A failed wheel sensor would be the most common cause, but there will be a code stored to point you in the right direction.
I think you haven't scanned the ABS module for faults because the codes you reported sound unrelated.Do you have any more thoughts on my first response?
Had it scanned my a VCDS and there were two codes: 00351 intermediate shaft speed sensor (G265) and PO341 - camshaft position sensor (G40)What POS scanner are you using?
I can't even.......The crankshaft sensor uses a 12 point socket to get it out and had to find a neighbor who had these sockets. They are not sold anymore.
So what you actually fixed was the brake pad wear warning light.And fixed the ABS light by completing the wiring circuit. I don't use the pads that you plug into this sensor. Light is now out.
Better stock up on 6-point sockets while you still canI can't even.......
Scanned the printout, but don't know how to attach. I can email it to you?OP, list your complete codes including freeze frame data from the autoscan since you clearly don't know how to decipher the information shown (or understand just how important it is) due to the fact that you're providing such limited information about your DTCs.
PUT A PIC ON MOUNTAIN/SOUTHWEST STATES OF THE READOUT.How to upload photos in Xenforo and use them in your posts
This is a temporary place holder for a proper FAQ on how to upload photos to the new system: To upload images to the image server: Go to the "Media" section. The link is found in the top bar. click on "Add Media" found near the top right corner. You will get a popup on where you want to...forums.tdiclub.com
Intermediate shaft speed sender G265 picks up a signal corresponding to the number of teeth on spur gear A at the torque output of planetary gears I and II.
