BeetleDragon737
I've got an ABS problem. My dash light is on, and with a VCDS scan, I get:
01276 - ABS Hydraulic Pump (V64)
16-00 - Signal Outside Specifications
From the ross-tech site:
Possible Symptoms
I'm not finding many people discussing this problem. Most people mention checking fuses on top of the battery, etc, but that's not a listed cause for this specific code. Reseating the fuses also did not help. I took a look at the connector between the ABS module and the pump, and it looks fine. No chafing or other damage. When it says "Wiring and/or Connector(s) faulty" which wires and connectors could it be talking about? Not the wheel speed sensors, right?
I recently did a bunch of brake and suspension work on the car and I'm expecting the light to be related, but I don't see how it could be. After the job, the reservoir had been bled dry, so I ran the brake bleed procedure a few times in addition to a standard bleed. Could running the pump dry have caused it to fail? If so, wouldn't that have been a mechanical failure rather than what appears to be an electrical failure here?
Do the pumps actually fail that frequently? Or is it more likely that it's just a coincidence this issue popped up now? Should I dig in there, pull the connector plug, clean it, and plug it back in? Any ideas?
Possible Symptoms
- Malfunction Indicator Light (MIL) ON
- ABS Hydraulic Pump (V64) Connector to Control Module faulty
- Wiring and/or Connector(s) faulty
- ABS Hydraulic Pump (V64) faulty
- Brake Electronics Control Module (J104) faulty
- Check ABS Hydraulic Pump (V64) Connector to Control Module
- Check Wiring and/or Connector(s)
- Check/Replace ABS Hydraulic Pump (V64)
- Check/Replace Brake Electronics Control Module (J104)
