STDOUBT
Recently replaced front calipers, hoses, pads and rotors. Did normal pressurized bleed at ~12 psi pushing air, seemed to go well, except - you guessed it: mushy pedal. No hard grab. Did a couple bed-in runs ~40 MPH, slam pedal down to 20 MPH. I think I still have air in the system.
I'm thinking I need to cycle the ABS pump, but I'm worried the pump will suck the reservoir dry before I can dump more fluid in.
How do you all ensure you have a good amount of gravity-fed fluid so you can do the whole cycling thing and not have to worry about sucking in air? No one seems to sell a big screw-on funnel for this.
Please advise.
Please advise.
