jimbote
Certified Volkswagen Nut
the subject: original 1.6D westy that my friend Don purchased from utah over a decade ago...my buddy converted it to an AAZ and then to run on straight WVO with an elsbett kit... I've mothballed the veggie system and in the process of converting it to a 1Z tdi from a 97' passat donor
the still beating heart with a gt2052 WG turbo ... pump will be swapped for a full E-TDI setup as i progress with the project
serpentine setup i've been working on, using an ALH balancer for slight underdrive and better reliability and a 1.6d t belt tensioner....no power steering at the moment but plans include adding an electric ps unit from a saturn VUE
intake is a pd130 unit with custom welded racepipe, yes that is a luk 17-050 dmf/clutch setup
clearancing for the LUK DMF setup
