Windjammer
No, it's all internal to the dsg.falcaineer said:Does the DSG have a clutch cylinder?
Ahhhh! Thank you for clearing that up. I ordered the VAG-COM today to get my pedal "firm" again ;-)Mach1 said:Pax, the manual doesn't contridict itself, there is two different bleeding procedures.
There is a prebleeding for doing the ABS unit.
Then there is a procedure for routine bleeding the wheels.
You need to do the prebleeding procedure to get the pedal firm again. Bleed it exactly like it says.(it even says, if you dont follow this procedure you will have a soft pedal).
Good luck with it..
