artificer
I have a problem with my AC, and have the "00819 - High Pressure Sensor (G65) 009 - Open or Short to Ground" fault code.
I did the "Engine module OUTPUT TESTS", and the fans turn. During the AC compressor clutch test it said I had 20.5bar of pressure.
I tried doing the output test for the HVAC, but it said conditions weren't met to allow it or something to that effect. Laptop battery died then, so I have to recharge it or run an extension cord to re-try it. Another thing that bothers me is that I had several can't make connection errors when in the HVAC section. How often do you normally see these?
Whats the next step? Any ideas of what I can try before just dropping $100 on the pressure sensor?
Michael
Michael
