The ECU in my 05 PD Jetta Wagen (engine code BEW) has a -Q at the end of the part number.Uwe said:If anyone would like this file, it's here:
http://www.ross-tech.com/vag-com/download/label-files/038-906-016-H.LBL
(Right click on the link to download it, left clicking will likely just show you the contents in your browser).
At some point we'll probably integrate that into the 03-01 redirection file so it's used by all BEW engines, not just the -H ECUs.
-Uwe-
Is there a vag-com label file for the BEW 038-916-016-Q engine yet?n1das said:The ECU in my 05 PD Jetta Wagen (engine code BEW) has a -Q at the end of the part number.
I picked up my 05 PD Wagen back in April '05. I'm not sure when the car was built.
Since nobody contacted me as requested (above), the answer is pretty much: no.technocrat said:Is there a vag-com label file for the BEW 038-916-016-Q engine yet?
I'm sorry that the adaptation file and block listing file for the 038-906-016-Q engine control module that I sent you the last week of December didn't help. I was going to email you and see if there was anything else I could do, but I was waiting because I knew you were in the process of moving.Sebastian said:Since nobody contacted me as requested (above), the answer is pretty much: no.
Sorry Rich, the file was helpful, but somehow (no clue why) my email folder got damaged and the file was gone. So nevermind my own mistakes/problems, hope this file now helps and as said, there are still gaps, e.g. the other adaptation channels and some more measuring blocks. These things will be filled, not today, but as soon as possible.RichS said:I'm sorry that the adaptation file and block listing file for the 038-906-016-Q engine control module that I sent you the last week of December didn't help. I was going to email you and see if there was anything else I could do, but I was waiting because I knew you were in the process of moving.
Sebastian,Sebastian said:Ok, here we go...
http://www.ross-tech.com/vag-com/download/label-files/03-01.lbl
http://www.ross-tech.com/vag-com/download/label-files/038-906-016-BEW.lbl
This file covers the following ECU's:
038-906-016-AG
038-906-016-H
038-906-016-Q
The file has been created from scratch to be used as template for future EDC16 files and does not contain the data of the old 038-906-016-H.LBL, if I find some more time, it will be completed with some more info about the other blocks.
Any hints/suggestions?
OK, so I had a flashing battery light tonight. I checked this group and first I had something like 20-some% loading and 14.3X supply voltage.Group 016 (additional heater)
Generator loading
Additional heater
Activation of heater elements
Voltage supply from ECM
Additional heater display is 8 digit number where, left to right, 1 =
nothing
nothing
ECT sensor inoperative
engine started within the last 10 seconds
engine speed below 870 rpm
battery voltage below 9 volts
generator inoperative
ECT exceeds 70 C-80C (158F - 176F), or intake air temp exceeds 5C (41F)
Activation of heater elements is a 2 digit number. Left digit = 1 when high heat output relay is on. Right digit = 1 when low heat output relay is on.
Does anyone have anything for a 038-906-16-ABSebastian said:Ok, here we go...
038-906-016-AG
038-906-016-H
038-906-016-Q
So...No?A_Shifter said:Can someone explain the procedure for testing groups 008 and 011 (3000rpm in 3rd at WOT etc)?
you want to do this on a rolling road or get someone on the computer while you drive.A_Shifter said:So...No?
Changed your alternator pulley yet? I did, charging went from 13.6 avg. to 14.2 avg.whitedog said:OK, so I had a flashing battery light tonight. I checked this group and first I had something like 20-some% loading and 14.3X supply voltage.
I had no flashing light at this time.
I shut off the engine then checked voltage: 13.2V. I then restarted engine and still no flashing battery light, but now I was at 99.X% loading and 12.1V.
I'm thinking grounds or regulator. What think you?
Is this readings OK?
The car is Eu Bora/Jetta ATD PD 100.
EGR duty cycle is always the same 84.5%, except when I press accelerate pedal. When the engine is accelerating duty cycle is lower. When engine accelerates to demanded rpm, it's back to 84.5%
